Hi, I have replaced that code, this time it worked (maybe before when I tried independentely I made some mistake somewhere not loading the package of moveit2 configs before executing it or at least thats what I think). The gripper closes fine and opens but now the problem is that after approaching the object, the arm instead of picking the object up it seems to colide with the object and make it fly away(it feels like the object is very light and at the slightest contact with the arm it moves, falls or flies away). This is the result from when I executed approach and retreat:
Cpp code for approach and retreat:
#include <moveit/move_group_interface/move_group_interface.h>
#include <moveit/planning_scene_interface/planning_scene_interface.h>
#include <moveit_msgs/msg/display_robot_state.hpp>
#include <moveit_msgs/msg/display_trajectory.hpp>
static const rclcpp::Logger LOGGER = rclcpp::get_logger(“move_group_demo”);
rclcpp::init(argc, argv);
rclcpp::NodeOptions node_options;
node_options.automatically_declare_parameters_from_overrides(true);
auto move_group_node =
rclcpp::Node::make_shared(“move_group_interface_tutorial”, node_options);
rclcpp::executors::SingleThreadedExecutor executor;
executor.add_node(move_group_node);
std::thread(&executor { executor.spin(); }).detach();
static const std::string PLANNING_GROUP_ARM = “ur_manipulator”;
static const std::string PLANNING_GROUP_GRIPPER = “gripper”;
moveit::planning_interface::MoveGroupInterface move_group_arm(
move_group_node, PLANNING_GROUP_ARM);
moveit::planning_interface::MoveGroupInterface move_group_gripper(
move_group_node, PLANNING_GROUP_GRIPPER);
const moveit::core::JointModelGroup *joint_model_group_arm =
move_group_arm.getCurrentState()->getJointModelGroup(PLANNING_GROUP_ARM);
const moveit::core::JointModelGroup *joint_model_group_gripper =
move_group_gripper.getCurrentState()->getJointModelGroup(
// Get Current State
moveit::core::RobotStatePtr current_state_arm =
move_group_arm.getCurrentState(10);
moveit::core::RobotStatePtr current_state_gripper =
move_group_gripper.getCurrentState(10);
std::vector joint_group_positions_arm;
std::vector joint_group_positions_gripper;
current_state_arm->copyJointGroupPositions(joint_model_group_arm,
joint_group_positions_arm);
current_state_gripper->copyJointGroupPositions(joint_model_group_gripper,
joint_group_positions_gripper);
// Go Home
move_group_arm.setStartStateToCurrentState();
move_group_gripper.setStartStateToCurrentState();
RCLCPP_INFO(LOGGER, “Going Home”);
// joint_group_positions_arm[0] = 0.00; // Shoulder Pan
joint_group_positions_arm[1] = -2.50; // Shoulder Lift
joint_group_positions_arm[2] = 1.50; // Elbow
joint_group_positions_arm[3] = -1.50; // Wrist 1
joint_group_positions_arm[4] = -1.55; // Wrist 2
// joint_group_positions_arm[5] = 0.00; // Wrist 3
move_group_arm.setJointValueTarget(joint_group_positions_arm);
moveit::planning_interface::MoveGroupInterface::Plan my_plan_arm;
bool success_arm = (move_group_arm.plan(my_plan_arm) ==
moveit::core::MoveItErrorCode::SUCCESS);
move_group_arm.execute(my_plan_arm);
// Pregrasp
RCLCPP_INFO(LOGGER, “Pregrasp Position”);
current_state_arm = move_group_arm.getCurrentState(10);
current_state_gripper = move_group_gripper.getCurrentState(10);
geometry_msgs::msg::Pose target_pose1;
target_pose1.orientation.x = -1.0;
target_pose1.orientation.y = 0.00;
target_pose1.orientation.z = 0.00;
target_pose1.orientation.w = 0.00;
target_pose1.position.x = 0.343;
target_pose1.position.y = 0.132;
target_pose1.position.z = 0.264;
move_group_arm.setPoseTarget(target_pose1);
// Execute
// Open Gripper
RCLCPP_INFO(LOGGER, “Open Gripper!”);
move_group_gripper.setNamedTarget(“gripper_open”);
moveit::planning_interface::MoveGroupInterface::Plan my_plan_gripper;
bool success_gripper = (move_group_gripper.plan(my_plan_gripper) ==
// Execute
move_group_gripper.execute(my_plan_gripper);
// Approach
RCLCPP_INFO(LOGGER, “Approach to object”);
float delta = 0.04;
target_pose1.position.z = target_pose1.position.z - delta;
// Execute
// Close Gripper
RCLCPP_INFO(LOGGER, “Close Gripper!”);
move_group_gripper.setNamedTarget(“gripper_close”);
// Execute
// Retreat
target_pose1.position.z = target_pose1.position.z + delta;
// Execute
// Open Gripper
// Execute
rclcpp::shutdown();
return 0;
This is the result of when I executed pick and place:
Cpp code for pick and place:
// Go Home
// Pregrasp
// Open Gripper
// Approach
RCLCPP_INFO(LOGGER, “Approach to object!”);
std::vector<geometry_msgs::msg::Pose> approach_waypoints;
target_pose1.position.z -= 0.03;
approach_waypoints.push_back(target_pose1);
moveit_msgs::msg::RobotTrajectory trajectory_approach;
const double jump_threshold = 0.0;
const double eef_step = 0.01;
double fraction = move_group_arm.computeCartesianPath(
approach_waypoints, eef_step, jump_threshold, trajectory_approach);
move_group_arm.execute(trajectory_approach);
// Close Gripper
// Retreat
RCLCPP_INFO(LOGGER, “Retreat from object!”);
std::vector<geometry_msgs::msg::Pose> retreat_waypoints;
target_pose1.position.z += 0.03;
retreat_waypoints.push_back(target_pose1);
moveit_msgs::msg::RobotTrajectory trajectory_retreat;
retreat_waypoints, eef_step, jump_threshold, trajectory_retreat);
move_group_arm.execute(trajectory_retreat);
// Place
RCLCPP_INFO(LOGGER, “Rotating Arm”);
joint_group_positions_arm[0] = 1.57; // Shoulder Pan
// Open Gripper
RCLCPP_INFO(LOGGER, “Release Object!”);
rclcpp::shutdown();
return 0;
If you would like to have a look at the animaton please let me know if there is a way to upload a small clip of the arm executing the trajectory.
Thanks again for your help. I am learning a lot with these tutorials.
