Just clicked on Open Course for ROS 2 URDF, but course unit shows 9.1 Course Project as first unit, then unable to check as complete nor going back to other sections. Simulation is also loading infinite time.
Hi @Genozen, that is strange
. I’ve tried to reproduce your error and wasn’t able to; the course loads correctly and I can switch between units with no issues.
Maybe the issue you had was a timeout in connectivity. Could you please try closing and running the course again after around 5 minutes?
If the problem persists please let us know
@Genozen
Watch the video below to see how to navigate the units.
