Hi, all
When I’m defining the <hardwareInterface> in a urdf file, the example give in the URDF course using <hardwareInterface>VelocityJointInterface</hardwareInterface>. While the example in the ROS control document uses <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface>.
I would like to know if there are any differences between using those two?
Cheers
