If so, then you need to review your CMakeLists.txt because it means you have not setup your C++ source file to be correctly compiled, as indicated in the notes.
The problem is that your C++ executable has not been compiled even if everything appears to be correctly setup. Check the following:
Did catkin_make run without errors, indicating that a C++ executable was being generated from your C++ source? In any case, try removing the build and devel folders and run the following again, taking note of the messages generated by catkin_make.
# run from catkin_ws directory
rm -rf build/ devel/
cakin_make
source devel/setup.bash
Did you copy CMakeLists.txt or package.xml? You should avoid copying CMakeLists.txt or package.xml - better to edit them manually, following the notes - to avoid typo errors that usually result. You should create your package with catkin_create_pkg and only copy source or launch files, if necessary. You should then manually edit the necessary sections of CMakeLists.txt and package.xml.
I tried as well to make sure that Ros takes the changes made through sourcing my workspace : source devel/setup.bash.
I made sure that the launch file is syntaxically correct.(btw , isn’t the launch of @herrsidje missing the " < launch >" and the “< /launch >” above and below ?
I thought as well that Ros haven’t detected my new created Package (in that case, I can’t use roslaunch) so I tried to referesh the package list using : rospack profile .
I think i have tried everything , but i still get the error:
… logging to /home/user/.ros/log/26fe808a-8295-11ed-9842-0242c0a8a006/roslaunch-1_xterm-6543.log
Press Ctrl-C to interrupt
ERROR: cannot launch node of type [topic_publisher_pkg/simple_topic_publisher]: Cannot locate node of type [simple_topic_publisher] in package [topic_publisher_pkg]. Make sure file exists in package path and permission is set to executable (chmod +x)
No processes to monitor
Okay I have just solved it through deleting : rm -rf build/ devel/ as @bayodesegun said. Any explanation for that deletion? This would be useful for futur use in case of not being able to roslaunch a package, I delete the build/devel/ and compile again!
