Error: "MoveGroupInterface::plan() failed or timeout reached" when I run "gripper_close"
While I was running my approach_retreat.cpp script in Section 3 of the course I realised that the gripper doesn’t close. Later when I tried to manually set the value with the lines below. The gripper closes. It also must be said that gripper_open does work.
joint_group_positions_gripper[2] = 0.55;
move_group_gripper.setJointValueTarget(joint_group_positions_gripper);
I then wrote the below code to help debug the problem, to check where the error is caused.
#include <moveit/move_group_interface/move_group_interface.h>
#include <moveit/planning_scene_interface/planning_scene_interface.h>
#include <moveit_msgs/msg/display_robot_state.hpp>
#include <moveit_msgs/msg/display_trajectory.hpp>
static const rclcpp::Logger LOGGER = rclcpp::get_logger("move_group_demo");
  rclcpp::init(argc, argv);
  rclcpp::NodeOptions node_options;
  node_options.automatically_declare_parameters_from_overrides(true);
  auto move_group_node = rclcpp::Node::make_shared("move_group_interface_tutorial", node_options);
  rclcpp::executors::SingleThreadedExecutor executor;
  executor.add_node(move_group_node);
  std::thread([&executor]() { executor.spin(); }).detach();
  static const std::string PLANNING_GROUP_GRIPPER = "gripper";
  moveit::planning_interface::MoveGroupInterface move_group_gripper(move_group_node, PLANNING_GROUP_GRIPPER);
  move_group_gripper.setPlanningTime(10.0); // Increase planning time to 10 seconds
  // Get current state
  const moveit::core::JointModelGroup *joint_model_group_gripper = move_group_gripper.getCurrentState()->getJointModelGroup(PLANNING_GROUP_GRIPPER);
  moveit::core::RobotStatePtr current_state_gripper = move_group_gripper.getCurrentState(10);
  std::vector<double> joint_group_positions_gripper;
  current_state_gripper->copyJointGroupPositions(joint_model_group_gripper, joint_group_positions_gripper);
  // Open Gripper
  RCLCPP_INFO(LOGGER, "Open Gripper using named target!");
  move_group_gripper.setNamedTarget("gripper_open");
  moveit::planning_interface::MoveGroupInterface::Plan my_plan_gripper;
  bool success_gripper = (move_group_gripper.plan(my_plan_gripper) == moveit::core::MoveItErrorCode::SUCCESS);
  if (success_gripper) {
    move_group_gripper.execute(my_plan_gripper);
  } else {
    RCLCPP_ERROR(LOGGER, "Planning failed for Opening Gripper using named target");
  // Close Gripper
  RCLCPP_INFO(LOGGER, "Close Gripper using named target!");
  move_group_gripper.setNamedTarget("gripper_close");
  } else {
    RCLCPP_ERROR(LOGGER, "Planning failed for Closing Gripper using named target");
    // Print debug information
    RCLCPP_INFO(LOGGER, "Joint values for gripper_open:");
    for (size_t i = 0; i < joint_group_positions_gripper.size(); ++i) {
      RCLCPP_INFO(LOGGER, "Joint %zu: %f", i, joint_group_positions_gripper[i]);
    RCLCPP_INFO(LOGGER, "Joint values for gripper_close:");
  rclcpp::shutdown();
  return 0;
After running this I found that I would get the Error “MoveGroupInterface::plan() failed or timeout reached” when gripper_close is run. I have added additional files below to help check if there was any mistake during moveit configuration.
name.srdf
<?xml version="1.0" encoding="UTF-8"?>
<!--This does not replace URDF, and is not an extension of URDF.
    This is a format for representing semantic information about the robot structure.
    A URDF file must exist for this robot as well, where the joints and the links that are referenced are defined
<robot name="name">
    <!--GROUPS: Representation of a set of joints and links. This can be useful for specifying DOF to plan for, defining arms, end effectors, etc-->
    <!--LINKS: When a link is specified, the parent joint of that link (if it exists) is automatically included-->
    <!--JOINTS: When a joint is specified, the child link of that joint (which will always exist) is automatically included-->
    <!--CHAINS: When a chain is specified, all the links along the chain (including endpoints) are included in the group. Additionally, all the joints that are parents to included links are also included. This means that joints along the chain and the parent joint of the base link are included in the group-->
    <!--SUBGROUPS: Groups can also be formed by referencing to already defined group names-->
    <group name="ur_manipulator">
        <chain base_link="base_link" tip_link="tool0"/>
    </group>
    <group name="gripper">
        <joint name="robotiq_85_base_joint"/>
        <joint name="robotiq_85_left_inner_knuckle_joint"/>
        <joint name="robotiq_85_left_finger_tip_joint"/>
        <joint name="robotiq_85_left_knuckle_joint"/>
        <joint name="robotiq_85_left_finger_joint"/>
        <joint name="robotiq_85_right_inner_knuckle_joint"/>
        <joint name="robotiq_85_right_finger_tip_joint"/>
        <joint name="robotiq_85_right_knuckle_joint"/>
        <joint name="robotiq_85_right_finger_joint"/>
    </group>
    <!--GROUP STATES: Purpose: Define a named state for a particular group, in terms of joint values. This is useful to define states like 'folded arms'-->
    <group_state name="home" group="ur_manipulator">
        <joint name="elbow_joint" value="1.5"/>
        <joint name="shoulder_lift_joint" value="-2.5"/>
        <joint name="shoulder_pan_joint" value="0"/>
        <joint name="wrist_1_joint" value="-1.5"/>
        <joint name="wrist_2_joint" value="-1.55"/>
        <joint name="wrist_3_joint" value="0"/>
    </group_state>
    <group_state name="gripper_open" group="gripper">
        <joint name="robotiq_85_left_knuckle_joint" value="0"/>
    </group_state>
    <group_state name="gripper_close" group="gripper">
        <joint name="robotiq_85_left_knuckle_joint" value="0.55"/>
    </group_state>
    <!--END EFFECTOR: Purpose: Represent information about an end effector.-->
    <end_effector name="hand_ee" parent_link="wrist_3_link" group="gripper" parent_group="ur_manipulator"/>
    <!--VIRTUAL JOINT: Purpose: this element defines a virtual joint between a robot link and an external frame of reference (considered fixed with respect to the robot)-->
    <virtual_joint name="fixed_base" type="fixed" parent_frame="world" child_link="base_link"/>
    <!--DISABLE COLLISIONS: By default it is assumed that any link of the robot could potentially come into collision with any other link in the robot. This tag disables collision checking between a specified pair of links. -->
    <disable_collisions link1="base_link_inertia" link2="ground_plane_box" reason="Adjacent"/>
    <disable_collisions link1="base_link_inertia" link2="shoulder_link" reason="Adjacent"/>
    <disable_collisions link1="base_link_inertia" link2="upper_arm_link" reason="Never"/>
    <disable_collisions link1="base_link_inertia" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="base_link_inertia" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="base_link_inertia" link2="wrist_rgbd_camera_link" reason="Adjacent"/>
    <disable_collisions link1="forearm_link" link2="upper_arm_link" reason="Adjacent"/>
    <disable_collisions link1="forearm_link" link2="wrist_1_link" reason="Adjacent"/>
    <disable_collisions link1="forearm_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="ground_plane_box" link2="shoulder_link" reason="Never"/>
    <disable_collisions link1="ground_plane_box" link2="wrist_rgbd_camera_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_base_link" link2="robotiq_85_left_finger_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_base_link" link2="robotiq_85_left_finger_tip_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_base_link" link2="robotiq_85_left_inner_knuckle_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_base_link" link2="robotiq_85_left_knuckle_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_base_link" link2="robotiq_85_right_finger_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_base_link" link2="robotiq_85_right_finger_tip_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_base_link" link2="robotiq_85_right_inner_knuckle_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_base_link" link2="robotiq_85_right_knuckle_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_base_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_base_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_base_link" link2="wrist_3_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_base_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="robotiq_85_left_finger_tip_link" reason="Default"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="robotiq_85_left_inner_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="robotiq_85_left_knuckle_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="robotiq_85_right_finger_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="robotiq_85_right_finger_tip_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="robotiq_85_right_inner_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="robotiq_85_right_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="wrist_3_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_tip_link" link2="robotiq_85_left_inner_knuckle_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_left_finger_tip_link" link2="robotiq_85_left_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_tip_link" link2="robotiq_85_right_finger_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_tip_link" link2="robotiq_85_right_inner_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_tip_link" link2="robotiq_85_right_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_tip_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_tip_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_tip_link" link2="wrist_3_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_finger_tip_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_inner_knuckle_link" link2="robotiq_85_left_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_inner_knuckle_link" link2="robotiq_85_right_finger_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_inner_knuckle_link" link2="robotiq_85_right_finger_tip_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_inner_knuckle_link" link2="robotiq_85_right_inner_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_inner_knuckle_link" link2="robotiq_85_right_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_inner_knuckle_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_inner_knuckle_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_inner_knuckle_link" link2="wrist_3_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_inner_knuckle_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_knuckle_link" link2="robotiq_85_right_finger_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_knuckle_link" link2="robotiq_85_right_finger_tip_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_knuckle_link" link2="robotiq_85_right_inner_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_knuckle_link" link2="robotiq_85_right_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_knuckle_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_knuckle_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_knuckle_link" link2="wrist_3_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_left_knuckle_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_link" link2="robotiq_85_right_finger_tip_link" reason="Default"/>
    <disable_collisions link1="robotiq_85_right_finger_link" link2="robotiq_85_right_inner_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_link" link2="robotiq_85_right_knuckle_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_right_finger_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_link" link2="wrist_3_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_tip_link" link2="robotiq_85_right_inner_knuckle_link" reason="Adjacent"/>
    <disable_collisions link1="robotiq_85_right_finger_tip_link" link2="robotiq_85_right_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_tip_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_tip_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_tip_link" link2="wrist_3_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_finger_tip_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_inner_knuckle_link" link2="robotiq_85_right_knuckle_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_inner_knuckle_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_inner_knuckle_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_inner_knuckle_link" link2="wrist_3_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_inner_knuckle_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_knuckle_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_knuckle_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_knuckle_link" link2="wrist_3_link" reason="Never"/>
    <disable_collisions link1="robotiq_85_right_knuckle_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="shoulder_link" link2="upper_arm_link" reason="Adjacent"/>
    <disable_collisions link1="shoulder_link" link2="wrist_1_link" reason="Never"/>
    <disable_collisions link1="shoulder_link" link2="wrist_2_link" reason="Never"/>
    <disable_collisions link1="shoulder_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="upper_arm_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="wrist_1_link" link2="wrist_2_link" reason="Adjacent"/>
    <disable_collisions link1="wrist_1_link" link2="wrist_3_link" reason="Never"/>
    <disable_collisions link1="wrist_1_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="wrist_2_link" link2="wrist_3_link" reason="Adjacent"/>
    <disable_collisions link1="wrist_2_link" link2="wrist_rgbd_camera_link" reason="Never"/>
    <disable_collisions link1="wrist_3_link" link2="wrist_rgbd_camera_link" reason="Never"/>
</robot>
robotic_85_gripper_macro.urdf.xacro
<?xml version="1.0"?>
<robot name="robotiq_85_gripper" xmlns:xacro="http://ros.org/wiki/xacro">
	<xacro:include filename="$(find robotiq_85_description)/urdf/robotiq_85_gripper.transmission.xacro" />
	<xacro:macro name="mimic_joint_plugin_gazebo" params="name_prefix parent_joint mimic_joint has_pid:=false multiplier:=1.0 offset:=0 sensitiveness:=0.0 max_effort:=1.0 robot_namespace:=''">
		<gazebo>
			<plugin name="${name_prefix}mimic_joint_plugin" filename="libroboticsgroup_gazebo_mimic_joint_plugin.so">
				<joint>${parent_joint}</joint>
				<mimicJoint>${mimic_joint}</mimicJoint>
				<xacro:if value="${has_pid}">                     <!-- if set to true, PID parameters from "/gazebo_ros_control/pid_gains/${mimic_joint}" are loaded -->
					<hasPID />
				</xacro:if>
				<multiplier>${multiplier}</multiplier>
				<offset>${offset}</offset>
				<sensitiveness>${sensitiveness}</sensitiveness>   <!-- if absolute difference between setpoint and process value is below this threshold, do nothing; 0.0 = disable [rad] -->
				<maxEffort>${max_effort}</maxEffort>              <!-- only taken into account if has_pid:=true [Nm] -->
				<xacro:unless value="${robot_namespace == ''}">
					<robotNamespace>($robot_namespace)</robotNamespace>
				</xacro:unless>
			</plugin>
		</gazebo>
	</xacro:macro>
	<xacro:macro name="robotiq_85_gripper" params="prefix parent *origin sim:=true">
		<!-- The current hardware driver does not depend on ros2_control but we do utilize
				 it for simulating the gripper in Gazebo. Enabling this on hardware causes the
				 JointStateBroadcaster to publish values for all joints including ones that are
				 mimic'd which is causing issues on systems consuming the joint_state data. -->
		<xacro:if value="${sim}">
			<!-- ros2 control include -->
			<xacro:include filename="$(find robotiq_85_description)/urdf/robotiq_85_gripper.ros2_control.xacro"/>
			<!-- ros2 control instance -->
			<xacro:robotiq_85_gripper_ros2_control name="RobotiqGripperSystem"/>
		</xacro:if>
		<joint name="${prefix}robotiq_85_base_joint" type="fixed">
			<parent link="${parent}"/>
			<child link="${prefix}robotiq_85_base_link"/>
			<xacro:insert_block name="origin"/>
		</joint>
		<link name="${prefix}robotiq_85_base_link">
			<!-- Visual aid for grasping -->
			<visual>
				<origin xyz="0.16 0 0" rpy="0 0 0" />
				<geometry>
					<sphere radius="0.007"/>
				</geometry>
				<material name="">
					<color rgba="0 1.0 0 1.0"/>
				</material>
			</visual>
			<!-- Gripper body -->
			<visual>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/visual/robotiq_85_base_link.dae"/>
				</geometry>
			</visual>
			<collision>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/collision/robotiq_85_base_link.stl"/>
				</geometry>
			</collision>
			<inertial>
				<mass value="0.636951" />
				<origin xyz="0.0 0.0 0.0" />
				<inertia ixx = "0.000380" ixy = "0.000000" ixz = "0.000000"
					iyx = "0.000000" iyy = "0.001110" iyz = "0.000000"
					izx = "0.000000" izy = "0.000000" izz = "0.001171" />
			</inertial>
		</link>
		<joint name="${prefix}robotiq_85_left_knuckle_joint" type="revolute">
			<parent link="${prefix}robotiq_85_base_link"/>
			<child link="${prefix}robotiq_85_left_knuckle_link"/>
			<axis xyz="0 0 1"/>
			<origin rpy="${pi} 0.0 0.0" xyz="0.05490451627 0.03060114443 0.0"/>
			<limit lower="0.0" upper="0.804" velocity="0.5" effort="50"/>
			<dynamics damping="100.0" />
		</joint>
		<gazebo reference="${prefix}robotiq_85_left_knuckle_link">
			<kp>1000000.0</kp>
			<kd>100.0</kd>
			<mu1>30.0</mu1>
			<mu2>30.0</mu2>
			<maxVel>1.0</maxVel>
			<minDepth>0.001</minDepth>
			<material>Gazebo/Grey</material>
		</gazebo>
		<joint name="${prefix}robotiq_85_right_knuckle_joint" type="continuous">
			<child link="${prefix}robotiq_85_right_knuckle_link"/>
			<axis xyz="0 0 1"/>
			<origin rpy="0.0 0.0 0.0" xyz="0.05490451627 -0.03060114443 0.0"/>
			<limit lower="-3.14" upper="3.14" velocity="100.0" effort="50"/>
			<mimic joint="${prefix}robotiq_85_left_knuckle_joint"/>
		</joint>
		<gazebo reference="${prefix}robotiq_85_right_knuckle_link">
			<kp>1000000.0</kp>
			<kd>100.0</kd>
			<mu1>30.0</mu1>
			<mu2>30.0</mu2>
		</gazebo>
		<xacro:mimic_joint_plugin_gazebo name_prefix="{prefix}robotiq_85_right_knuckle_joint"
			parent_joint="${prefix}robotiq_85_left_knuckle_joint" mimic_joint="${prefix}robotiq_85_right_knuckle_joint"
			multiplier="1.0" max_effort="10.0" />
		<link name="${prefix}robotiq_85_left_knuckle_link">
			<visual>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/visual/robotiq_85_knuckle_link.dae"/>
				</geometry>
			</visual>
			<collision>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/collision/robotiq_85_knuckle_link.stl"/>
				</geometry>
			</collision>
			<inertial>
				<mass value="0.018491" />
				<inertia ixx = "0.000009" ixy = "-0.000001" ixz = "0.000000"
					iyx = "-0.000001" iyy = "0.000001" iyz = "0.000000"
					izx = "0.000000" izy = "0.000000" izz = "0.000010" />
			</inertial>
		</link>
		<link name="${prefix}robotiq_85_right_knuckle_link">
			<visual>
				<geometry>
				</geometry>
			</visual>
			<collision>
				<geometry>
				</geometry>
			</collision>
			<inertial>
			</inertial>
		</link>
		<joint name="${prefix}robotiq_85_left_finger_joint" type="fixed">
			<parent link="${prefix}robotiq_85_left_knuckle_link"/>
			<child link="${prefix}robotiq_85_left_finger_link"/>
			<origin xyz="-0.00408552455 -0.03148604435 0.0" rpy="0 0 0" />
		</joint>
		<joint name="${prefix}robotiq_85_right_finger_joint" type="fixed">
			<parent link="${prefix}robotiq_85_right_knuckle_link"/>
			<child link="${prefix}robotiq_85_right_finger_link"/>
		</joint>
		<link name="${prefix}robotiq_85_left_finger_link">
			<visual>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/visual/robotiq_85_finger_link.dae"/>
				</geometry>
			</visual>
			<collision>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/collision/robotiq_85_finger_link.stl"/>
				</geometry>
			</collision>
			<inertial>
				<mass value="0.027309" />
				<inertia ixx = "0.000003" ixy = "-0.000002" ixz = "0.000000"
					iyx = "-0.000002" iyy = "0.000021" iyz = "0.000000"
					izx = "0.000000" izy = "0.000000" izz = "0.000020" />
			</inertial>
		</link>
		<link name="${prefix}robotiq_85_right_finger_link">
			<visual>
				<geometry>
				</geometry>
			</visual>
			<collision>
				<geometry>
				</geometry>
			</collision>
			<inertial>
			</inertial>
		</link>
		<joint name="${prefix}robotiq_85_left_inner_knuckle_joint" type="continuous">
			<child link="${prefix}robotiq_85_left_inner_knuckle_link"/>
			<axis xyz="0 0 1"/>
			<origin xyz="0.06142 0.0127 0" rpy="${pi} 0.0 0.0" />
			<limit lower="-3.14" upper="3.14" velocity="100.0" effort="0.1"/>
			<mimic joint="${prefix}robotiq_85_left_knuckle_joint" offset="0"/>
		</joint>
		<xacro:mimic_joint_plugin_gazebo name_prefix="${prefix}robotiq_85_left_inner_knuckle_joint"
			parent_joint="${prefix}robotiq_85_left_knuckle_joint" mimic_joint="${prefix}robotiq_85_left_inner_knuckle_joint"
		<joint name="${prefix}robotiq_85_right_inner_knuckle_joint" type="continuous">
			<child link="${prefix}robotiq_85_right_inner_knuckle_link"/>
			<axis xyz="0 0 1"/>
			<origin xyz="0.06142 -0.0127 0" rpy="0 0 0"/>
		</joint>
		<xacro:mimic_joint_plugin_gazebo name_prefix="${prefix}robotiq_85_right_inner_knuckle_joint"
			parent_joint="${prefix}robotiq_85_left_knuckle_joint" mimic_joint="${prefix}robotiq_85_right_inner_knuckle_joint"
		<link name="${prefix}robotiq_85_left_inner_knuckle_link">
			<visual>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/visual/robotiq_85_inner_knuckle_link.dae"/>
				</geometry>
			</visual>
			<collision>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/collision/robotiq_85_inner_knuckle_link.stl"/>
				</geometry>
			</collision>
			<inertial>
				<mass value="0.029951" />
				<inertia ixx = "0.000039" ixy = "0.000000" ixz = "0.000000"
					iyx = "0.000000" iyy = "0.000005" iyz = "0.000000"
					izx = "0.000000" izy = "0.000000" izz = "0.000035" />
			</inertial>
		</link>
		<link name="${prefix}robotiq_85_right_inner_knuckle_link">
			<visual>
				<geometry>
				</geometry>
			</visual>
			<collision>
				<geometry>
				</geometry>
			</collision>
			<inertial>
			</inertial>
		</link>
		<joint name="${prefix}robotiq_85_left_finger_tip_joint" type="continuous">
			<parent link="${prefix}robotiq_85_left_inner_knuckle_link"/>
			<child link="${prefix}robotiq_85_left_finger_tip_link"/>
			<axis xyz="0 0 1"/>
			<origin xyz="0.04303959807 -0.03759940821 0.0" rpy="0.0 0.0 0.0"/>
			<mimic joint="${prefix}robotiq_85_left_knuckle_joint" multiplier="-1"/>
		</joint>
		<xacro:mimic_joint_plugin_gazebo name_prefix="${prefix}robotiq_85_left_finger_tip_joint"
			parent_joint="${prefix}robotiq_85_left_knuckle_joint" mimic_joint="${prefix}robotiq_85_left_finger_tip_joint"
		<joint name="${prefix}robotiq_85_right_finger_tip_joint" type="continuous">
			<parent link="${prefix}robotiq_85_right_inner_knuckle_link"/>
			<child link="${prefix}robotiq_85_right_finger_tip_link"/>
			<axis xyz="0 0 1"/>
			<origin rpy="0.0 0.0 0.0" xyz="0.04303959807 -0.03759940821  0.0"/>
		</joint>
		<xacro:mimic_joint_plugin_gazebo name_prefix="${prefix}robotiq_85_right_finger_tip_joint"
			parent_joint="${prefix}robotiq_85_left_knuckle_joint" mimic_joint="${prefix}robotiq_85_right_finger_tip_joint"
		<link name="${prefix}robotiq_85_left_finger_tip_link">
			<visual>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/visual/robotiq_85_finger_tip_link.dae"/>
				</geometry>
			</visual>
			<collision>
				<geometry>
					<mesh filename="package://robotiq_85_description/meshes/collision/robotiq_85_finger_tip_link.stl"/>
				</geometry>
			</collision>
			<inertial>
				<mass value="0.019555" />
				<inertia ixx = "0.000002" ixy = "0.000000" ixz = "0.000000"
					izx = "0.000000" izy = "0.000000" izz = "0.000006" />
			</inertial>
		</link>
		<gazebo reference="${prefix}robotiq_85_left_finger_tip_link">
			<kp>1000000.0</kp>
			<kd>100.0</kd>
			<mu1>30.0</mu1>
			<mu2>30.0</mu2>
		</gazebo>
		<link name="${prefix}robotiq_85_right_finger_tip_link">
			<visual>
				<geometry>
				</geometry>
			</visual>
			<collision>
				<geometry>
				</geometry>
			</collision>
			<inertial>
			</inertial>
		</link>
		<gazebo reference="${prefix}robotiq_85_right_finger_tip_link">
			<kp>1000000.0</kp>
			<kd>100.0</kd>
			<mu1>30.0</mu1>
			<mu2>30.0</mu2>
		</gazebo>
		<xacro:robotiq_85_gripper_transmission prefix="${prefix}" />
	</xacro:macro>
</robot>
Hello @neilthomas110 ,
I’ve just tested the example code you shared, and it’s working perfectly for me:
test-gripper
The only difference is that I’m using my Moveit2 config package. However, I don’t see anything strange in the files you shared (you don’t need to touch anything in the robotic_85_gripper_macro.urdf.xacro file though). This is the SRDF file I have:
<robot name="name">
    </group>
    </group>
    </group_state>
    <group_state name="open" group="gripper">
    </group_state>
    <group_state name="close" group="gripper">
    </group_state>
</robot>
Are you still experiencing the same issue?
I tried using your name.srdf but that did not resolve the problem.
If “gripper_open” (I used this target in other exercises) works why isn’t “gripper_close” working is what I am unable to understand. I haven’t manually added anything in the moveit config files.
Hi @neilthomas110 ,
From what Alberto has mentioned:
It seems to me that you have not configured your MoveIt configuration package properly.
Delete the old moveit config package and create a new one with Setup Assistant.
Alternatively, you can also modify your existing moveit config package using Setup Assistant.
Make sure that when you are creating or editing your moveit package, set the values for self-collision matrix to maximum values.
