I’m trying to run a simulation of a ur10e in rviz. The planning seems to be working fine, but the execution is failing.
[move_group-4] [ERROR] [1711012747.785348441] [moveit.simple_controller_manager.follow_joint_trajectory_controller_handle]: Action client not connected to action server: ur_manipulator_controller/follow_joint_trajectory
[move_group-4] [ERROR] [1711012747.785351894] [moveit_ros.trajectory_execution_manager]: Failed to send trajectory part 1 of 1 to controller ur_manipulator_controller
[move_group-4] [INFO] [1711012747.785355290] [moveit_ros.trajectory_execution_manager]: Completed trajectory execution with status ABORTED …
[move_group-4] [INFO] [1711012747.785390210] [moveit_move_group_default_capabilities.execute_trajectory_action_capability]: Execution completed: ABORTED
[rviz2-6] [INFO] [1711012747.785594970] [move_group_interface]: Execute request aborted
[rviz2-6] [ERROR] [1711012747.786399287] [move_group_interface]: MoveGroupInterface::execute() failed or timeout reached
This is a section of the traceback which includes the errors i’ve got. I’ve checked the moveit_controllers.yaml file and listed the actions to make sure that the follow_joint_trajectory action_ns was under the ur_manipulator_controller.
This is how my moveit_controllers.yaml file looks:
moveit_controller_manager: moveit_simple_controller_manager/MoveItSimpleControllerManager
moveit_simple_controller_manager:
controller_names:
- ur_manipulator_controller
ur_manipulator_controller:
type: FollowJointTrajectory
action_ns: follow_joint_trajectory
default: true
joints:
- shoulder_pan_joint
- shoulder_lift_joint
- elbow_joint
- wrist_1_joint
- wrist_2_joint
- wrist_3_joint
default: true
Any suggestions on how I can fix this?
Thanks!
