I tried to implement a root-link along with the base link and the roll_M1_link. Initially I wanted to make a floating joint between the root-link (fixed to the world) and the base-link (could move around if required) but apparently it is not supported.
Even when rviz converted the ‘floating joint’ into a ‘fixed joint’, I get the error under ‘RobotModel’: “No transform from [root_link] to [base_link]”.
How can I resolve this?
Edit: I cannot even select the [root link] as my Fixed-frame
<?xml version="1.0"?>
<robot name="mira">
<!--Material Descriptions-->
<gazebo reference="base_link">
<kp>100000.0</kp>
<kd>100000.0</kd>
<mu1>10.0</mu1>
<mu2>10.0</mu2>
<material>Gazebo/Grey</material>
</gazebo>
<gazebo reference="roll_M1_link">
<kp>100000.0</kp>
<kd>100000.0</kd>
<mu1>10.0</mu1>
<mu2>10.0</mu2>
<material>Gazebo/White</material>
</gazebo>
<!-- * * * Link Definitions * * * -->
<link name="root_link">
<visual>
<origin rpy="0 0 0" xyz="0 0 0"/>
<geometry>
<box size="0.1 0.1 0.01"/>
</geometry>
</visual>
</link>
<link name="base_link">
<inertial>
<mass value="0.18" />
<inertia
ixx="0.0002835" ixy="0.0" ixz="0.0"
iyy="0.0002835" iyz="0.0"
izz="0.000324"/>
</inertial>
<collision>
<geometry>
<cylinder radius="0.06" length="0.09"/>
</geometry>
</collision>
<visual>
<geometry>
<!--mesh filename="package://my_mira_description/models/mira/meshes/mira_body_v3.dae"/-->
</geometry>
</visual>
</link>
<link name="roll_M1_link">
<inertial>
<mass value="0.01" />
<inertia
ixx="0.0000000270833" ixy="0.0" ixz="0.0"
iyy="0.0000000270833" iyz="0.0"
izz="0.00000005"/>
</inertial>
<visual>
<geometry>
<cylinder radius="0.01" length="0.005"/>
</geometry>
</visual>
</link>
<!--Joint Descriptions-->
<joint name="free_joint" type="floating">
<parent link="root_link"/>
<child link="base_link"/>
</joint>
<joint name="roll_joint" type="revolute">
<parent link="base_link"/>
<child link="roll_M1_link"/>
<limit lower="-0.2" upper="0.2" effort="0.1" velocity="0.005"/>
<axis xyz="1 0 0"/>
</joint>
</robot>
