- Exercise 2.1 Unit 2 of robot dynamics
In unit 2 of this course, exercise 2.1 says error on gazebo_utils.services. as this is in robot_dynamics_files, where it works fine, but when created another pkg in src directory named push_box then it has problem…but instruction written in exercise to create new pkg in src folder…kindly help
regards
Hello @misbahsuhail123 ,
Do you mean an error in the IDE (the code highlited in red) or when running the code? Because I’ve been testing it and it’s working fine. However, there is a bug in the IDE which may cause some imports to be highlited as errors (but they do actually work fine so they can be ignored).
