@staff In the URDF course, Unit 5, below program is used to move the gurdy robot.
gurdy_demo_v1.py
#!/usr/bin/env python
import time
from math import pi, sin, cos, acos
import random
from std_msgs.msg import Float64
from sensor_msgs.msg import JointState
Topics To Write on:
type: std_msgs/Float64
/gurdy/head_upperlegM1_joint_position_controller/command
/gurdy/head_upperlegM2_joint_position_controller/command
/gurdy/head_upperlegM3_joint_position_controller/command
/gurdy/upperlegM1_lowerlegM1_joint_position_controller/command
/gurdy/upperlegM2_lowerlegM2_joint_position_controller/command
/gurdy/upperlegM3_lowerlegM3_joint_position_controller/command
class gurdyJointMover(object):
rospy.init_node('jointmover_demo', anonymous=True)
rospy.loginfo("Gurdy JointMover Initialising...")
self.pub_upperlegM1_joint_position = rospy.Publisher(
'/gurdy/head_upperlegM1_joint_position_controller/command',
Float64,
queue_size=1)
self.pub_upperlegM2_joint_position = rospy.Publisher(
'/gurdy/head_upperlegM2_joint_position_controller/command',
Float64,
queue_size=1)
self.pub_upperlegM3_joint_position = rospy.Publisher(
'/gurdy/head_upperlegM3_joint_position_controller/command',
Float64,
queue_size=1)
self.pub_lowerlegM1_joint_position = rospy.Publisher(
'/gurdy/upperlegM1_lowerlegM1_joint_position_controller/command',
Float64,
queue_size=1)
self.pub_lowerlegM2_joint_position = rospy.Publisher(
'/gurdy/upperlegM2_lowerlegM2_joint_position_controller/command',
Float64,
queue_size=1)
self.pub_lowerlegM3_joint_position = rospy.Publisher(
'/gurdy/upperlegM3_lowerlegM3_joint_position_controller/command',
Float64,
queue_size=1)
joint_states_topic_name = "/gurdy/joint_states"
rospy.Subscriber(joint_states_topic_name, JointState, self.gurdy_joints_callback)
gurdy_joints_data = None
rate = rospy.Rate(2)
while gurdy_joints_data is None:
try:
gurdy_joints_data = rospy.wait_for_message(joint_states_topic_name, JointState, timeout=5)
except:
rospy.logwarn("Time out " + str(joint_states_topic_name))
pass
rate.sleep()
self.gurdy_joint_dictionary = dict(zip(gurdy_joints_data.name, gurdy_joints_data.position))
def move_gurdy_all_joints(self, upperlegM1_angle, upperlegM2_angle, upperlegM3_angle, lowerlegM1_value, lowerlegM2_value ,lowerlegM3_value):
upperlegM1 = Float64()
upperlegM1.data = upperlegM1_angle
upperlegM2 = Float64()
upperlegM2.data = upperlegM2_angle
upperlegM3 = Float64()
upperlegM3.data = upperlegM3_angle
lowerlegM1 = Float64()
lowerlegM1.data = lowerlegM1_value
lowerlegM2 = Float64()
lowerlegM2.data = lowerlegM2_value
lowerlegM3 = Float64()
lowerlegM3.data = lowerlegM3_value
self.pub_upperlegM1_joint_position.publish(upperlegM1)
self.pub_upperlegM2_joint_position.publish(upperlegM2)
self.pub_upperlegM3_joint_position.publish(upperlegM3)
self.pub_lowerlegM1_joint_position.publish(lowerlegM1)
self.pub_lowerlegM2_joint_position.publish(lowerlegM2)
self.pub_lowerlegM3_joint_position.publish(lowerlegM3)
def gurdy_joints_callback(self, msg):
sensor_msgs/JointState
std_msgs/Header header
uint32 seq
time stamp
string frame_id
string[] name
float64[] position
float64[] velocity
float64[] effort
:param msg:
:return:
self.gurdy_joint_dictionary = dict(zip(msg.name, msg.position))
def convert_angle_to_unitary(self, angle):
Removes complete revolutions from angle and converts to the positive equivalent
if the angle is negative
:param angle: Has to be in radians
:return:
# Convert to angle between [0,360)
complete_rev = 2 * pi
mod_angle = int(angle / complete_rev)
clean_angle = angle - mod_angle * complete_rev
# Convert Negative angles to their corresponding positive values
if clean_angle < 0:
clean_angle += 2 * pi
return clean_angle
def assertAlmostEqualAngles(self, x, y,):
c2 = (sin(x) - sin(y)) ** 2 + (cos(x) - cos(y)) ** 2
angle_diff = acos((2.0 - c2) / 2.0)
return angle_diff
def gurdy_check_continuous_joint_value(self, joint_name, value, error=0.1):
Check the joint by name 'base_waist_joint', 'body_head_joint', 'waist_body_joint is near the value given
We have to convert the joint values removing whole revolutions and converting negative versions
of the same angle
:param joint_name:
:param value:
:param error: In radians
:return:
joint_reading = self.gurdy_joint_dictionary.get(joint_name)
if not joint_reading:
print("self.gurdy_joint_dictionary="+str(self.gurdy_joint_dictionary))
print("joint_name===>"+str(joint_name))
assert "There is no data about that joint"
clean_joint_reading = self.convert_angle_to_unitary(angle=joint_reading)
clean_value = self.convert_angle_to_unitary(angle=value)
dif_angles = self.assertAlmostEqualAngles(clean_joint_reading, clean_value)
similar = dif_angles <= error
return similar
def gurdy_movement_look(self, upperlegM1_angle, upperlegM2_angle, upperlegM3_angle, lowerlegM1_value, lowerlegM2_value ,lowerlegM3_value):
Move:
'head_upperlegM1_joint',
'head_upperlegM2_joint',
'head_upperlegM3_joint',
'upperlegM1_lowerlegM1_joint',
'upperlegM2_lowerlegM2_joint',
'upperlegM3_lowerlegM3_joint'
:return:
check_rate = 5.0
position_upperlegM1 = upperlegM1_angle
position_upperlegM2 = upperlegM2_angle
position_upperlegM3 = upperlegM3_angle
position_lowerlegM1 = lowerlegM1_value
position_lowerlegM2 = lowerlegM2_value
position_lowerlegM3 = lowerlegM3_value
similar_upperlegM1 = False
similar_upperlegM2 = False
similar_upperlegM3 = False
similar_lowerlegM1 = False
similar_lowerlegM2 = False
similar_lowerlegM3 = False
rate = rospy.Rate(check_rate)
while not (similar_upperlegM1 and similar_upperlegM2 and similar_upperlegM3 and similar_lowerlegM1 and similar_lowerlegM2 and similar_lowerlegM3):
self.move_gurdy_all_joints(position_upperlegM1,
position_upperlegM2,
position_upperlegM3,
position_lowerlegM1,
position_lowerlegM2,
position_lowerlegM3)
similar_upperlegM1 = self.gurdy_check_continuous_joint_value(joint_name="head_upperlegM1_joint",
value=position_upperlegM1)
similar_upperlegM2 = self.gurdy_check_continuous_joint_value(joint_name="head_upperlegM2_joint",
value=position_upperlegM2)
similar_upperlegM3 = self.gurdy_check_continuous_joint_value(joint_name="head_upperlegM3_joint",
value=position_upperlegM3)
similar_lowerlegM1 = self.gurdy_check_continuous_joint_value(joint_name="upperlegM1_lowerlegM1_joint",
value=position_lowerlegM1)
similar_lowerlegM2 = self.gurdy_check_continuous_joint_value(joint_name="upperlegM2_lowerlegM2_joint",
value=position_lowerlegM2)
similar_lowerlegM3 = self.gurdy_check_continuous_joint_value(joint_name="upperlegM3_lowerlegM3_joint",
value=position_lowerlegM3)
rate.sleep()
def gurdy_init_pos_sequence(self):
UPPER limits lower="-1.55" upper="0.0"
LOWER limits lower="-2.9" upper="1.5708"
:return:
upperlegM1_angle = -1.55
upperlegM2_angle = -1.55
upperlegM3_angle = -1.55
lowerlegM1_angle = 0.0
lowerlegM2_angle = 0.0
lowerlegM3_angle = 0.0
self.gurdy_movement_look(upperlegM1_angle,
upperlegM2_angle,
upperlegM3_angle,
lowerlegM1_angle,
lowerlegM2_angle,
lowerlegM3_angle)
lowerlegM1_angle = -1.55
lowerlegM2_angle = -1.55
lowerlegM3_angle = -1.55
upperlegM2_angle,
upperlegM3_angle,
lowerlegM1_angle,
lowerlegM2_angle,
lowerlegM3_angle)
def gurdy_hop(self, num_hops=15):
:return:
upper_delta = 1
basic_angle = -1.55
angle_change = random.uniform(0.2, 0.7)
upperlegM_angle = basic_angle
lowerlegM_angle = basic_angle - upper_delta * angle_change * 2.0
#self.gurdy_init_pos_sequence()
for repetitions in range(num_hops):
self.gurdy_movement_look(upperlegM_angle,
upperlegM_angle,
upperlegM_angle,
lowerlegM_angle,
lowerlegM_angle,
lowerlegM_angle)
upper_delta *= -1
if upper_delta < 0:
upperlegM_angle = basic_angle + angle_change
else:
def gurdy_moverandomly(self):
:return:
upperlegM1_angle = random.uniform(-1.55, 0.0)
upperlegM2_angle = random.uniform(-1.55, 0.0)
upperlegM3_angle = random.uniform(-1.55, 0.0)
lowerlegM1_angle = random.uniform(-2.9, pi/2)
lowerlegM2_angle = random.uniform(-2.9, pi/2)
lowerlegM3_angle = random.uniform(-2.9, pi/2)
upperlegM2_angle,
upperlegM3_angle,
lowerlegM1_angle,
lowerlegM2_angle,
lowerlegM3_angle)
def movement_random_loop(self):
Executed movements in a random way
:return:
rospy.loginfo("Start Moving Gurdy...")
#self.gurdy_moverandomly()
self.gurdy_hop()
if __name__ == "__main__":
gurdy_jointmover_object = gurdyJointMover()
gurdy_jointmover_object.movement_random_loop()
Question 1:
What does wait_for_message in gurdy_joints_data = rospy.wait_for_message(joint_states_topic_name, JointState, timeout=5) mean?
The definition from link rospy.client says that This will create a new subscription to the topic, receive one message, then unsubscribe.
Does this mean that after we have received a return message ,the node will unsubscribe from that topic? If yes, how will future callbacks be called?
Question 2:
return angle_diff
We are using the above function to check if we have reached the goal or not, with x being the joint_reading and y being the destination angle. Instead, why not just use y-x instead of
c2 = (sin(x) - sin(y)) ** 2 + (cos(x) - cos(y)) ** 2 angle_diff = acos((2.0 - c2) / 2.0) ?
