In ROS Kinetic, I ran the command roslaunch pr2_description robot_description.launch.
There were no error messages but even after many minutes awaiting Gazebo does not bring up the model. I clicked on the open Gazebo icon and it is a black screen. I also refreshed and reloaded multiple times but still does not work.
Actually it’s not an issue, because the file you are trying to launch only start robot state publisher and joint state publisher.
In order to have the simulation, you can launch the file pointed in the notebook, which is pick_place_project_mod.launch or if you want the robot spawned only to try your own programs, use this launch file robot_spawn.launch
Be aware this rosject is quite advanced, that’s why it has a documentation in the notebooks, so you can understand everything that is happening inside the simulation.
In that case, the launch file is starting a world, spawning the robot, starting the controllers and also showing a demo.
There are many things to be taken into account, not only launching the description nodes for a robot.
Please, let me know if the indicated launch file worked for you.
I reviewed the rosject and found a few small errors. I have corrected them and updated the notebook with proper instructions for launching the simulation.
Thank you so much @rtellez! I truly appreciate it.
How do we launch the robots in the public simulation in the command line? I have tried the following:
source /home/simulations/public_sim_ws/devel/setup.bash
