Get stuck at openai_ros package at "model.train"
Hi Experts,
I am using openai_ros package to drive a ur5e simulation model to reach a cricket_ball goal(as my graduate project). It should be easy, but it turned out to be not. I used the similar case of “shadow_tc”. But the training stuck at the “model.train” step.
I think the biggest reason is the env set up is not right.
Could any Expert help? Thank you very much!!
When I do the env.check, it showed nothing. just stuck.
I am using Ubunt 20.04. ROS NOETIC. and I am using stable_baselines as the RL library, I also tried stable_baselines3 for the RL. But the model just stuck.
Still no idea, could any expert give a hand?
Hi, any experts here? Thanks!
