Grasping_msgs does not work
Hello
I want to build the package on the last part of the ROS2 Manipulator course and I get this error:
I tried to install the grasping_msgs package manually with
sudo apt update
sudo apt install ros-humble-grasping-msgs
But this did not solve the issue.
So I also tried with cloning the package
git clone -b ros2 https://github.com/mikeferguson/grasping_msgs.git`
But this did also not resolve the issue.
It is weird, because yesterday it did work. And today I am getting this error without having changed anything.
Any help please
Which specific package are you trying to build? Is it moveit2_scripts?
moveit2_scripts is the package that had this error, and the error was that it could not find the dependency grasping_msgs/action/.....
In addition to ensuring that the grasping_msgs package is available, you also need to ensure that it is properly included as a dependency in moveit2_scripts, and the best way to do that is to include it when creating that package.
Hi @bayodesegun
Thanks for the response. You were right, there was a little mistake in the CMakeList.
