I used the multi_map_merge package to merge map from robot 1 and robot 2. But when I used rosrun map_server map_saver -f ~/map , the map is only saved the merge map which is from /map topic as shown in image below. But I also would like to save map from /tb3_0/map and /tb3_1/map topics. I would like to ask how to save map according to the map topics? Thank you in advance.
Yes, the proper command is:
map_server map_saver -f ~/map map:=/your/costmap/topic
This topic was automatically closed after 7 days. New replies are no longer allowed.
