Hello everybody,
We usually choose to easily configure the parameters by loading the parameters in the yaml file via rosparam, like this:
<launch>
<param name="move_base/base_local_planner" type="string" value="dwa_local_planner/DWAPlannerROS"/>
<rosparam file="$(find turn_on_wheeltec_robot)/params_nav_common/dwa_local_planner_params.yaml" command="load" ns="move_base"/>
</launch>
We load the parameters in dwa_local_planner_params.yaml via rosparam in the launch file.
But I have a problem, this will make me load all the parameters in this file, but if I only need some of the parameters in this yaml file, how do I do it?
Like this, here is a test.yaml file and I only need the accel_lim_v and accel_lim_w parameters in it, how can I do it?
speed_lim_v: 1.5
speed_lim_w: 3.14
accel_lim_v: 0.5
accel_lim_w: 0.3
frequency: 30.0
decel_factor: 1.0
robot_feedback: 0
All I can think of at the moment is to save the parameters I need in a separate yaml file that does not contain other data.
Thank you,
zlwnge
