I am doing the exercise 4.6. I do not know what I changed, but when launching any file that sends parameters to the arm, the following occurs:
See here
user:~/ros2_ws$ ros2 launch moveit2_scripts test_trajectory_2.launch.py
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2022-09-27-14-45-59-192340-2_xterm-22184
Task exception was never retrieved
future: <Task finished name='Task-2' coro=<LaunchService._process_one_event() done, defined at /opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py:226> exception=SubstitutionFailure('executed command failed. Command: /opt/ros/noetic/bin/xacro /home/user/ros2_ws/install/ur_e_description/share/ur_e_description/urdf/ur3e_robot.urdf.xacro safety_limits:=true safety_pos_margin:=0.15 safety_k_position:=20 name:=ur prefix:="" ')>
File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py", line 228, in _process_one_event
await self.__process_event(next_event)
File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py", line 248, in __process_event
visit_all_entities_and_collect_futures(entity, self.__context))
File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py", line 45, in visit_all_entities_and_collect_futures
futures_to_return += visit_all_entities_and_collect_futures(sub_entity, context)
[Previous line repeated 1 more time]
File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py", line 38, in visit_all_entities_and_collect_futures
sub_entities = entity.visit(context)
File "/opt/ros/foxy/lib/python3.8/site-packages/launch/action.py", line 108, in visit
return self.execute(context)
File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/actions/node.py", line 422, in execute
self._perform_substitutions(context)
File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/actions/node.py", line 382, in _perform_substitutions
evaluated_parameters = evaluate_parameters(context, self.__parameters)
File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/utilities/evaluate_parameters.py", line 145, in evaluate_parameters
output_params.append(evaluate_parameter_dict(context, param))
File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/utilities/evaluate_parameters.py", line 69, in evaluate_parameter_dict
evaluated_value = perform_substitutions(context, list(value))
File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/perform_substitutions_impl.py", line 26, in perform_substitutions
return ''.join([context.perform_substitution(sub) for sub in subs])
File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/perform_substitutions_impl.py", line 26, in <listcomp>
File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_context.py", line 197, in perform_substitution
return substitution.perform(self)
File "/opt/ros/foxy/lib/python3.8/site-packages/launch/substitutions/command.py", line 116, in perform
raise SubstitutionFailure(f'executed command failed. Command: {command_str}')
launch.substitutions.substitution_failure.SubstitutionFailure: executed command failed. Command: /opt/ros/noetic/bin/xacro /home/user/ros2_ws/install/ur_e_description/share/ur_e_description/urdf/ur3e_robot.urdf.xacro safety_limits:=true safety_pos_margin:=0.15 safety_k_position:=20 name:=ur prefix:=""
I have tried multiple times deleting the install & build folders, with no success.
UPDATE:
Today (14h later) it works ![]()
