Hi guys. I’m trying to use a rplidar to run amcl navigation with my pre-built map on Turtlebot2, ROS Kinetic. Below is my amcl launch file:
<launch>
<!-- Define laser type-->
<arg name="laser_sensor" default="$(env TURTLEBOT_LASER_SENSOR)" />
<!-- <arg name="laser_sensor" default="rplidar" /> -->
<!-- laser driver -->
<include file="$(find turtlebot_navigation)/laser/driver/$(arg laser_sensor)_laser.launch" />
<!-- Map server -->
<arg name="map_file" default="$(env TURTLEBOT_MAP_FILE)"/>
<node name="map_server" pkg="map_server" type="map_server" args="$(arg map_file)" />
<!-- AMCL -->
<arg name="custom_amcl_launch_file" default="$(find turtlebot_navigation)/launch/includes/amcl/$(arg laser_sensor)_amcl.launch.xml"/>
<arg name="initial_pose_x" default="0.0"/> <!-- Use 17.0 for willow's map in simulation -->
<arg name="initial_pose_y" default="0.0"/> <!-- Use 17.0 for willow's map in simulation -->
<arg name="initial_pose_a" default="0.0"/>
<include file="$(arg custom_amcl_launch_file)">
<arg name="initial_pose_x" value="$(arg initial_pose_x)"/>
<arg name="initial_pose_y" value="$(arg initial_pose_y)"/>
<arg name="initial_pose_a" value="$(arg initial_pose_a)"/>
</include>
<!-- Move base -->
<arg name="custom_param_file" default="$(find turtlebot_navigation)/param/$(arg laser_sensor)_costmap_params.yaml"/>
<include file="$(find turtlebot_navigation)/launch/includes/rplidar_move_base.launch.xml">
<arg name="custom_param_file" value="$(arg custom_param_file)"/>
</include>
</launch>
where the “laser_sensor” is the used LiDAR. But the weird thing is that when I ran this launch file, the /scan topic came from a camera node rather than the pre-defined lidarNode. Here is the rqt_graph. However, when I ran cartographer SLAM, the /scan topic was correctly published by the desired lidarNode. I have no idea why this went wrong with the navigation. I don’t even equip the turtlebot2 with a camera. Could someone explain how to fix it? I really appreciate your help!
