I got stuck with this error.
Hi @AshishVarma ,
Did you search this error in the forum before posting this?
I have seen a lot of posts of this very same error.
Anyways, to know what is wrong you need to backtrack your package.
- Did you make the proper changes to the
CMakeLists.txtfile andpackage.xmlfile? - Did you add the
msgfile intoCMakeLists.txt? - Is your
Age.msgfile error-free? Do you have copy-paste errors or any hidden characters? - Did you source your workspace before launching the package after building your package?
- If you ran it on a new terminal, did you source your workspace?
Next time please post the complete set of error from the terminal as a code-block.
@girishkumar.kannan I have checked once again I am sure that I have not done anything wrong in these possibilities.
My launch file → ex4_3.launch
<launch>
<node pkg="my_subscriber_example_pkg" type="publish_age.py" name="publish_age_node" output="screen" />
</launch>
My script file → publish_age.py
from my_subscriber_example_pkg.msg import Age
rospy.init_node('publish_age_node')
pub = rospy.Publisher('/age_info', Age, queue_size=1)
rate = rospy.Rate(2)
age = Age()
age.years = 5
age.months = 10
age.days = 21
pub.publish(age)
rate.sleep()
CMakeLists.txt file
project(my_subscriber_example_pkg)
rospy
std_msgs
message_generation
# catkin_python_setup()
## * In the file package.xml:
add_message_files(
FILES
Message1.msg
Message2.msg
Age.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
INCLUDE_DIRS include
LIBRARIES my_subscriber_example_pkg
CATKIN_DEPENDS rospy std_msgs
DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/my_subscriber_example_pkg.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/my_subscriber_example_pkg_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_my_subscriber_example_pkg.cpp)
# endif()
# catkin_add_nosetests(test)
package.xml file
<?xml version="1.0"?>
<package format="2">
<name>my_subscriber_example_pkg</name>
<version>0.0.0</version>
<description>The my_subscriber_example_pkg package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/my_subscriber_example_pkg</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<export>
</export>
</package>
Iam using the following cmds for launching file
roscd; cd …
catkin_make
source devel/setup.bash
roslaunch my_subscriber_example_pkg ex4_3.launch
Hi @AshishVarma ,
You do not have Message1.msg and Message2.msg defined in your package. Remove them from your CMakeLists.txt.
Your package.xml looks fine.
Just post your entire error output from your terminal as code-block if you still have this issue.
updated file
rospy
std_msgs
message_generation
add_message_files(
FILES
Age.msg
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
std_msgs
catkin_package(
DEPENDS system_lib
## Build ##
# include
## Install ##
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# endif()
still getting the same error.
... logging to /home/user/.ros/log/68f6f838-b4ee-11ed-a62c-0242c0a83006/roslaunch-3_xterm-12359.log
Press Ctrl-C to interrupt
started roslaunch server http://3_xterm:41639/
SUMMARY
PARAMETERS
* /rosdistro: noetic
* /rosversion: 1.15.9
NODES
publish_age_node (my_subscriber_example_pkg/publish_age.py)
ROS_MASTER_URI=http://3_simulation:11311
process[publish_age_node-1]: started with pid [12367]
File "/home/user/catkin_ws/src/my_subscriber_example_pkg/scripts/publish_age.py", line 4, in <module>
from my_subscriber_example_pkg.msg import Age #Import Age message from the exercise_33 package
ModuleNotFoundError: No module named 'my_subscriber_example_pkg'
[publish_age_node-1] process has died [pid 12367, exit code 1, cmd /home/user/catkin_ws/src/my_subscriber_example_pkg/scripts/publish_age.py __name:=publish_age_node __log:=/home/user/.ros/log/68f6f838-b4ee-11ed-a62c-0242c0a83006/publish_age_node-1.log].
log file: /home/user/.ros/log/68f6f838-b4ee-11ed-a62c-0242c0a83006/publish_age_node-1*.log
done
Hi @AshishVarma ,
Try the following commands:
cd ~/catkin_ws
catkin_make --only-pkg-with-deps my_subscriber_example_pkg
Try this and let me know if you still get that error message.
same error again.
cd ~/catkin_ws
user:~/catkin_ws$ catkin_make --only-pkg-with-deps my_subscriber_example_pkg
Whitelisted packages: my_subscriber_example_pkg
#### Running command: "cmake /home/user/catkin_ws/src -DCATKIN_DEVEL_PREFIX=/home/user/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/user/catkin_ws/install -DCATKIN_WHITELIST_PACKAGES=my_subscriber_example_pkg -G Unix Makefiles" in "/home/user/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/user/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /home/user/catkin_ws/devel;/home/simulations/public_sim_ws/devel;/opt/ros/noetic
-- This workspace overlays: /home/user/catkin_ws/devel;/home/simulations/public_sim_ws/devel;/opt/ros/noetic
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.5", minimum required is "3")
-- Using PYTHON_EXECUTABLE: /usr/bin/python3
-- Using Debian Python package layout
-- Using empy: /usr/lib/python3/dist-packages/em.py
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/user/catkin_ws/build/test_results
-- Forcing gtest/gmock from source, though one was otherwise available.
-- Found gtest sources under '/usr/src/googletest': gtests will be built
-- Found gmock sources under '/usr/src/googletest': gmock will be built
-- Found PythonInterp: /usr/bin/python3 (found version "3.8.5")
-- Using Python nosetests: /usr/bin/nosetests3
-- catkin 0.8.9
-- BUILD_SHARED_LIBS is on
-- Using CATKIN_WHITELIST_PACKAGES: my_subscriber_example_pkg
-- ~~ traversing 1 packages in topological order:
-- ~~ - my_subscriber_example_pkg
-- +++ processing catkin package: 'my_subscriber_example_pkg'
-- ==> add_subdirectory(my_subscriber_example_pkg)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- my_subscriber_example_pkg: 1 messages, 0 services
CMake Warning at /opt/ros/noetic/share/catkin/cmake/catkin_package.cmake:166 (message):
catkin_package() DEPENDS on 'system_lib' but neither
'system_lib_INCLUDE_DIRS' nor 'system_lib_LIBRARIES' is defined.
/opt/ros/noetic/share/catkin/cmake/catkin_package.cmake:102 (_catkin_package)
my_subscriber_example_pkg/CMakeLists.txt:104 (catkin_package)
CMake Error at /opt/ros/noetic/share/catkin/cmake/catkin_package.cmake:305 (message):
catkin_package() include dir 'include' does not exist relative to
'/home/user/catkin_ws/src/my_subscriber_example_pkg'
-- Configuring incomplete, errors occurred!
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
user:~/catkin_ws$ source devel/setup.bash
user:~/catkin_ws$ roslaunch my_subscriber_example_pkg ex4_3.launch
... logging to /home/user/.ros/log/68f6f838-b4ee-11ed-a62c-0242c0a83006/roslaunch-3_xterm-13504.log
started roslaunch server http://3_xterm:37217/
SUMMARY
PARAMETERS
NODES
process[publish_age_node-1]: started with pid [13512]
ImportError: cannot import name 'Age' from 'my_subscriber_example_pkg.msg' (unknown location)
[publish_age_node-1] process has died [pid 13512, exit code 1, cmd /home/user/catkin_ws/src/my_subscriber_example_pkg/scripts/publish_age.py __name:=publish_age_node __log:=/home/user/.ros/log/68f6f838-b4ee-11ed-a62c-0242c0a83006/publish_age_node-1.log].
done
Hi @AshishVarma ,
Ah! Your catkin_make itself is failing.
Try these command set:
cd ~/catkin_ws
rm -rf ./build ./devel
catkin_make && source devel/setup.bash
Let me know how this works.
error again.
user:~/catkin_ws$ cd ~/catkin_ws
user:~/catkin_ws$ rm -rf ./build ./devel
user:~/catkin_ws$ catkin_make && source devel/setup.bash
#### Running command: "cmake /home/user/catkin_ws/src -DCATKIN_DEVEL_PREFIX=/home/user/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/user/catkin_ws/install -G Unix Makefiles" in "/home/user/catkin_ws/build"
-- The C compiler identification is GNU 9.3.0
-- The CXX compiler identification is GNU 9.3.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found PY_em: /usr/lib/python3/dist-packages/em.py
-- Found Threads: TRUE
-- catkin 0.8.9
-- ~~ traversing 3 packages in topological order:
-- ~~ - my_package
-- ~~ - my_publisher_example_pkg
-- +++ processing catkin package: 'my_package'
-- ==> add_subdirectory(my_package)
-- +++ processing catkin package: 'my_publisher_example_pkg'
-- ==> add_subdirectory(my_publisher_example_pkg)
... logging to /home/user/.ros/log/68f6f838-b4ee-11ed-a62c-0242c0a83006/roslaunch-3_xterm-14588.log
started roslaunch server http://3_xterm:41667/
SUMMARY
PARAMETERS
NODES
process[publish_age_node-1]: started with pid [14596]
[publish_age_node-1] process has died [pid 14596, exit code 1, cmd /home/user/catkin_ws/src/my_subscriber_example_pkg/scripts/publish_age.py __name:=publish_age_node __log:=/home/user/.ros/log/68f6f838-b4ee-11ed-a62c-0242c0a83006/publish_age_node-1.log].
done
Hi @AshishVarma ,
I think I found out your problem.
You have uncommented every line inside catkin_package(...) inside CMakeLists.txt.
Please change the following:
catkin_package(
DEPENDS system_lib
To this way:
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES my_subscriber_example_pkg
# DEPENDS system_lib
And then do:
cd ~/catkin_ws
This should fix your issue I think.
Let me know the result.
@girishkumar.kannan yeah sir that’s actually worked. thank you sir.
could you please share me what the actual problem is? I am a beginner so i cant actually know whats the error is…
Hi @AshishVarma ,
I know this time it will work.
Your lack of attention was the problem here.
Follow the course material correctly.
It specifically states in the course material to uncomment CATKIN_DEPENDS line inside catkin_package(...) within the CMakeLists.txt file.
You uncommented everything in that function and you felt confident!
I specifically said this in my initial reply:
For which you said:
I hope you understand this and not make similar mistakes in the future.
