Multi-joint control yaml-file
Hello everyone,
I am trying to implement a multi-joint effort-position/velocity controller (not Trajectory Controller). I tried to copy the structure of a Joint-Trajectory controller, since I observed that the trajectory controller accepts an array of inputs for each time-step.
The reason I am attempting this is because I want to avoid any sources of delays in sending out commands to the joints when I want them all to move according to a sequence given to it by a black-box function. Since the physical-robot publishes commands to the motor over an n-size array for n-dof, I felt it might be nice to attempt it.
My Yaml-file is as such:
# https://github.com/ros-industrial/ur_modern_driver/issues/305
ros_control_namespace: "/"
# MoveIt-specific simulation settings
# Settings for ros_control control loop
generic_hw_control_loop:
    loop_hz: 200
    cycle_time_error_threshold: 0.01
# Settings for ros_control hardware interface
hardware_interface:
    joints:
        - wam/J1
        - wam/J2
        - wam/J3
        - wam/J4
        - wam/J5
        - wam/J6
        - wam/J7
controller_list:
    -   name: eff_based_pos_traj_controller
        action_ns: wam_follow_joint_trajectory
        default: True
        type: FollowJointTrajectory
        joints:
            - wam/J1
            - wam/J2
            - wam/J3
            - wam/J4
            - wam/J5
            - wam/J6
            - wam/J7
    -   name: eff_based_pos_controller
        action_ns: wam_follow_joint_pos
        default: True
        type: std_msgs/Float64
        joints:
            - wam/J1
            - wam/J2
            - wam/J3
            - wam/J4
            - wam/J5
            - wam/J6
            - wam/J7
    -   name: eff_based_vel_controller
        action_ns: wam_follow_joint_vel
        default: True
        joints:
            - wam/J1
            - wam/J2
            - wam/J3
            - wam/J4
            - wam/J5
            - wam/J6
            - wam/J7
# Reference values
# https://git.barrett.com/software/libbarrett_ros/blob/ros_control/config/wam_config.yaml
eff_based_pos_traj_controller:
    type: effort_controllers/JointTrajectoryController
    joints:
        - wam/J1
        - wam/J2
        - wam/J3
        - wam/J4
        - wam/J5
        - wam/J6
        - wam/J7
    constraints:
        goal_time: 1000
        stopped_velocity_tolerance: 0.05
        wam/J1: {trajectory: 0.1, goal: 0.1}
        wam/J2: {trajectory: 0.1, goal: 0.1}
        wam/J3: {trajectory: 0.1, goal: 0.1}
        wam/J4: {trajectory: 0.1, goal: 0.1}
        wam/J5: {trajectory: 0.1, goal: 0.1}
        wam/J6: {trajectory: 0.1, goal: 0.1}
        wam/J7: {trajectory: 0.1, goal: 0.1}
    stop_trajectory_duration: 0.5
    state_publish_rate:  200
    action_monitor_rate: 200
    gains:
        wam/J1:
            p: 900
            d: 10
            i: 2.5
            i_clamp: 0
        wam/J2:
            p: 2500
            d: 20
            i: 5
            i_clamp: 0
        wam/J3:
            p: 600
            d: 5
            i: 2
            i_clamp: 0
        wam/J4:
            p: 300
            d: 2
            i: 0.5
            i_clamp: 0
        wam/J5:
            p: 50
            d: 0.5
            i: 0.5
            i_clamp: 0
        wam/J6:
            p: 50
            d: 0.5
            i: 0.5
            i_clamp: 0
        wam/J7:
            p: 8
            d: 0.05
            i: 0.1
            i_clamp: 0
eff_based_pos_controller:
    # Reference values
    # https://github.com/ros-industrial-attic/ur_modern_driver/issues/305
    # Position Controllers ---------------------------------------
    type: effort_controllers/JointPositionController
    joints:
        - wam/J1
        - wam/J2
        - wam/J3
        - wam/J4
        - wam/J5
        - wam/J6
        - wam/J7
    constraints:
        goal_time: 1000
        wam/J1: {goal: 0.1}
        wam/J2: {goal: 0.1}
        wam/J3: {goal: 0.1}
        wam/J4: {goal: 0.1}
        wam/J5: {goal: 0.1}
        wam/J6: {goal: 0.1}
        wam/J7: {goal: 0.1}
    gains:
        wam/J1:
            p: 900
            d: 10
            i: 2.5
            i_clamp: 0
        wam/J2:
            p: 2500
            d: 20
            i: 5
            i_clamp: 0
        wam/J3:
            p: 600
            d: 5
            i: 2
            i_clamp: 0
        wam/J4:
            p: 300
            d: 2
            i: 0.5
            i_clamp: 0
        wam/J5:
            p: 50
            d: 0.5
            i: 0.5
            i_clamp: 0
        wam/J6:
            p: 50
            d: 0.5
            i: 0.5
            i_clamp: 0
        wam/J7:
            p: 8
            d: 0.05
            i: 0.1
            i_clamp: 0
eff_based_vel_controller:
    # Reference values
    # Velocity Controllers ---------------------------------------
    type: effort_controllers/JointVelocityController
    joints:
        - wam/J1
        - wam/J2
        - wam/J3
        - wam/J4
        - wam/J5
        - wam/J6
        - wam/J7
    constraints:
        goal_time: 1000
        wam/J1: {goal: 0.1}
        wam/J2: {goal: 0.1}
        wam/J3: {goal: 0.1}
        wam/J4: {goal: 0.1}
        wam/J5: {goal: 0.1}
        wam/J6: {goal: 0.1}
        wam/J7: {goal: 0.1}
    gains:
        wam/J1:
            p: 42
            d: 0
            i: 0
            i_clamp: 0
        wam/J2:
            p: 42
            d: 0
            i: 0
            i_clamp: 0
        wam/J3:
            p: 18
            d: 0
            i: 0
            i_clamp: 0
        wam/J4:
            p: 18
            d: 0
            i: 0
            i_clamp: 0
        wam/J5:
            p: 3
            d: 0
            i: 0
            i_clamp: 0
        wam/J6:
            p: 3
            d: 0
            i: 0
            i_clamp: 0
        wam/J7:
            p: 3
            d: 0
            i: 0.1
            i_clamp: 0
Any feedback would be most appreciated.
