Navigation stops after a few tens of centimeters when using namespace (TurtleBot3 + Nav2)
Overview:
I am attempting to run multi-robot navigation on ROS2 Humble (TurtleBot3 Burger) with namespaces.
However, each robot moves only a short distance (10–20 cm) and then starts rotating left/right on the spot indefinitely, failing to reach the goal.
This occurs consistently, regardless of the goal position.
Environment:
  • ROS2 Humble
  • TurtleBot3 Burger
  • Each robot launched with namespace (robot1, robot2, …)
  • Bringup & Navigation run on the robot
  • Map server & RViz run on the PC
Launch Commands:
# PC: Map publish & Rviz start
ros2 launch
# Robot: Robot bringup
ros2 launch turtlebot3_bringup robot.launch.py use_sim_time:=false namespace:=robot1
# Robot: Scan republisher (to change topic & TF names)
ros2 launch multi_robot_nav scan_republisher.launch.py
# Robot: Navigation
ros2 launch turtlebot3_navigation2 navigation2.launch.py use_sim_time:=false namespace:=robot1
# Robot: Send goal
ros2 launch multi_robot_nav send_goal.launch.py
TF Tree:
map
└── robot1/odom
   └── robot1/base_footprint
      └── robot1/base_link
         ├── robot1/caster_back_link
         ├── robot1/imu_link
         ├── robot1/base_scan
         ├── robot1/wheel_left_link
         └── robot1/wheel_right_link
Observed issue:
  • Robot moves normally only for 10–20 cm
  • Then the controller fails → robot starts spinning in place
  • No obstacle in RViz
  • Local costmap and global costmap appear normal
  • TF tree seems valid (posted above)
What I have already tried:
  • Changed DDS (CycloneDDS, FastDDS)
  • Adjusted parameters in burger.yaml
  • Rechecked TF prefixes / frame IDs
But the issue persists.
Question:
What could cause Nav2 to stop partway and start oscillating in place when using namespaces?
Are there known issues with TurtleBot3 + Nav2 + TF prefixing?
Any guidance would be greatly appreciated.
Thanks.
【log & code】
(Base:ROS2 Standard Packages: “turtlebot3_bringup”, “turtlebot3_navigation2”)
navigation log
[component_container_isolated-1] [INFO] [1763561788.435824324] [robot1.bt_navigator]: Begin navigating from current location (0.05, 0.03) to (0.80, 0.50)
[component_container_isolated-1] [INFO] [1763561788.457830657] [robot1.controller_server]: Received a goal, begin computing control effort.
[component_container_isolated-1] [WARN] [1763561788.460015926] [robot1.controller_server]: No goal checker was specified in parameter 'current_goal_checker'. Server will use only plugin loaded general_goal_checker . This warning will appear once.
[component_container_isolated-1] [ERROR] [1763561788.898115960] [DWBLocalPlanner]: 1.00: BaseObstacle/Trajectory Hits Obstacle.
[component_container_isolated-1] [WARN] [1763561788.899029059] [robot1.controller_server]: No valid trajectories out of 819!
[component_container_isolated-1] [INFO] [1763561789.560778784] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561790.560781045] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561791.560782196] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561792.660781674] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561793.660760974] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561794.660770161] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561795.660756071] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561796.760782383] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561797.760782496] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [ERROR] [1763561798.560944896] [robot1.controller_server]: Failed to make progress
[component_container_isolated-1] [WARN] [1763561798.561194726] [robot1.controller_server]: [follow_path] [ActionServer] Aborting handle.
[component_container_isolated-1] [INFO] [1763561798.576717308] [robot1.local_costmap.local_costmap]: Received request to clear entirely the local_costmap
[component_container_isolated-1] [INFO] [1763561798.578956224] [robot1.controller_server]: Received a goal, begin computing control effort.
[component_container_isolated-1] [WARN] [1763561798.734336241] [robot1.controller_server]: Control loop missed its desired rate of 10.0000Hz
[component_container_isolated-1] [INFO] [1763561798.781184074] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561799.780915987] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561800.880957003] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561801.881399629] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561802.881019877] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561803.982154656] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561804.980914823] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561805.981014509] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561807.080968636] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561808.080916214] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [ERROR] [1763561808.781147266] [robot1.controller_server]: Failed to make progress
[component_container_isolated-1] [WARN] [1763561808.781888627] [robot1.controller_server]: [follow_path] [ActionServer] Aborting handle.
[component_container_isolated-1] [INFO] [1763561808.796704625] [robot1.local_costmap.local_costmap]: Received request to clear entirely the local_costmap
[component_container_isolated-1] [INFO] [1763561808.798519676] [robot1.global_costmap.global_costmap]: Received request to clear entirely the global_costmap
[component_container_isolated-1] [WARN] [1763561809.450987833] [robot1.planner_server]: Planner loop missed its desired rate of 20.0000 Hz. Current loop rate is 1.5374 Hz
[component_container_isolated-1] [INFO] [1763561809.468583406] [robot1.controller_server]: Received a goal, begin computing control effort.
[component_container_isolated-1] [INFO] [1763561810.569219266] [robot1.controller_server]: Passing new path to controller.
[component_container_isolated-1] [INFO] [1763561811.569238916] [robot1.controller_server]: Passing new path to controller.
from launch.actions import DeclareLaunchArgument
from launch.substitutions import LaunchConfiguration
import os
    namespace = LaunchConfiguration('namespace', default='robot1')
    use_sim_time = LaunchConfiguration('use_sim_time', default='false')
    scan_republisher_node = Node(
        package='robot_system_demo',
        executable='scan_republisher',
        name='scan_republisher',
        namespace=namespace,
        parameters=[{'use_sim_time': use_sim_time}],
        output='screen'
    ld = LaunchDescription()
    ld.add_action(DeclareLaunchArgument('namespace', default_value='robot1'))
    ld.add_action(DeclareLaunchArgument('use_sim_time', default_value='false'))
    ld.add_action(scan_republisher_node)
    return ld
scan_republisher.cpp
#include <rclcpp/rclcpp.hpp>
#include <sensor_msgs/msg/laser_scan.hpp>
class ScanRepublisher : public rclcpp::Node
public:
    ScanRepublisher() : Node("scan_republisher")
        std::string input_topic = "/robot1/scan";
        std::string output_topic = "/robot1/scan_repub";
        rclcpp::SensorDataQoS qos;
        pub_ = this->create_publisher<sensor_msgs::msg::LaserScan>(output_topic, qos);
        sub_ = this->create_subscription<sensor_msgs::msg::LaserScan>(
            input_topic,
            qos,
            std::bind(&ScanRepublisher::scan_callback, this, std::placeholders::_1)
        RCLCPP_INFO(this->get_logger(), "ScanRepublisher started: %s -> %s",
                    input_topic.c_str(), output_topic.c_str());
private:
    void scan_callback(const sensor_msgs::msg::LaserScan::SharedPtr msg)
        auto new_msg = *msg;
        new_msg.header.frame_id = "robot1/base_scan";
        pub_->publish(new_msg);
        RCLCPP_DEBUG(this->get_logger(), "Republished scan, angle_min=%f", msg->angle_min);
    rclcpp::Publisher<sensor_msgs::msg::LaserScan>::SharedPtr pub_;
    rclcpp::Subscription<sensor_msgs::msg::LaserScan>::SharedPtr sub_;
int main(int argc, char **argv)
    rclcpp::init(argc, argv);
    auto node = std::make_shared<ScanRepublisher>();
    rclcpp::spin(node);
    rclcpp::shutdown();
    return 0;
navigation2.launch.py (Modified lines only)
IncludeLaunchDescription(
    PythonLaunchDescriptionSource([nav2_launch_file_dir, '/bringup_launch.py']),
    launch_arguments={
        'namespace': namespace,
        'map': '', # modified
        'use_sim_time': use_sim_time,
        'params_file': param_dir}.items(),
burger.yaml
amcl:
  ros__parameters:
    use_sim_time: False
    alpha1: 0.2
    alpha2: 0.2
    alpha3: 0.2
    alpha4: 0.2
    alpha5: 0.2
    base_frame_id: "robot1/base_footprint"
    beam_skip_distance: 0.5
    beam_skip_error_threshold: 0.9
    beam_skip_threshold: 0.3
    do_beamskip: false
    global_frame_id: "map"
    lambda_short: 0.1
    laser_likelihood_max_dist: 2.0
    laser_max_range: 100.0
    laser_min_range: -1.0
    laser_model_type: "likelihood_field"
    max_beams: 60
    max_particles: 2000
    min_particles: 500
    odom_frame_id: "robot1/odom"
    pf_err: 0.05
    pf_z: 0.99
    recovery_alpha_fast: 0.0
    recovery_alpha_slow: 0.0
    resample_interval: 1
    robot_model_type: "nav2_amcl::DifferentialMotionModel"
    save_pose_rate: 0.5
    sigma_hit: 0.2
    tf_broadcast: true
    transform_tolerance: 1.0
    update_min_a: 0.2
    update_min_d: 0.25
    z_hit: 0.5
    z_max: 0.05
    z_rand: 0.5
    z_short: 0.05
    scan_topic: "scan_repub"
    map_topic: "/map"
amcl_map_client:
  ros__parameters:
    use_sim_time: False
amcl_rclcpp_node:
  ros__parameters:
    use_sim_time: False
bt_navigator:
  ros__parameters:
    use_sim_time: False
    global_frame: "map"
    robot_base_frame: "robot1/base_link"
    odom_topic: "odom"
    default_bt_xml_filename: "/opt/ros/humble/share/nav2_bt_navigator/behavior_t
rees/navigate_to_pose_w_replanning_and_recovery.xml"
    bt_loop_duration: 10
    default_server_timeout: 20
    enable_groot_monitoring: True
    groot_zmq_publisher_port: 1666
    groot_zmq_server_port: 1667
    plugin_lib_names:
    - nav2_compute_path_through_poses_action_bt_node
    - nav2_back_up_action_bt_node
    - nav2_spin_action_bt_node
    - nav2_wait_action_bt_node
    - nav2_recovery_node_bt_node
    - nav2_single_trigger_bt_node
    - nav2_is_battery_low_condition_bt_node
    - nav2_navigate_through_poses_action_bt_node
    - nav2_navigate_to_pose_action_bt_node
    - nav2_remove_passed_goals_action_bt_node
    - nav2_planner_selector_bt_node
    - nav2_controller_selector_bt_node
    - nav2_goal_checker_selector_bt_node
bt_navigator_rclcpp_node:
  ros__parameters:
    use_sim_time: False
controller_server:
  ros__parameters:
    use_sim_time: False
    controller_frequency: 10.0
    min_y_velocity_threshold: 0.5
    failure_tolerance: 0.3
    progress_checker_plugin: "progress_checker"
    goal_checker_plugins: ["general_goal_checker"]
    controller_plugins: ["FollowPath"]
    # Progress checker parameters
    progress_checker:
      required_movement_radius: 0.5
      movement_time_allowance: 10.0
    general_goal_checker:
      stateful: True
      xy_goal_tolerance: 0.25
      yaw_goal_tolerance: 0.25
    # DWB parameters
    FollowPath:
      min_vel_x: 0.0
      min_vel_y: 0.0
      max_vel_x: 0.22
      max_vel_y: 0.0
      max_vel_theta: 1.0
      min_speed_xy: 0.0
      max_speed_xy: 0.22
      min_speed_theta: 0.0
      # Add high threshold velocity for turtlebot 3 issue.
      # https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
      acc_lim_x: 2.5
      acc_lim_y: 0.0
      acc_lim_theta: 3.2
      decel_lim_x: -2.5
      decel_lim_y: 0.0
      decel_lim_theta: -3.2
      vx_samples: 20
      vy_samples: 0
      vtheta_samples: 40
      sim_time: 1.5
      linear_granularity: 0.05
      angular_granularity: 0.025
      xy_goal_tolerance: 0.05
      trans_stopped_velocity: 0.25
      stateful: True
      critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "Pat
hAlign", "PathDist", "GoalDist"]
      BaseObstacle.scale: 0.02
      PathAlign.scale: 32.0
      GoalAlign.scale: 24.0
      PathDist.scale: 32.0
      GoalDist.scale: 24.0
      RotateToGoal.scale: 32.0
controller_server_rclcpp_node:
  ros__parameters:
    use_sim_time: False
local_costmap:
  local_costmap:
    ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      global_frame: "robot1/odom"
      robot_base_frame: "robot1/base_footprint"
      use_sim_time: False
      rolling_window: true
      width: 3
      height: 3
      resolution: 0.05
      robot_radius: 0.1
      plugins: ["obstacle_layer", "voxel_layer", "inflation_layer"]
      inflation_layer:
        plugin: "nav2_costmap_2d::InflationLayer"
        inflation_radius: 1.0
        cost_scaling_factor: 3.0
      obstacle_layer:
        plugin: "nav2_costmap_2d::ObstacleLayer"
        enabled: True
        observation_sources: "scan"
        scan:
          topic: "/robot1/scan_repub"
          max_obstacle_height: 2.0
          scan_frame: "robot1/base_scan"
          clearing: True
          marking: True
          data_type: "LaserScan"
      voxel_layer:
        plugin: "nav2_costmap_2d::VoxelLayer"
        enabled: True
        publish_voxel_map: True
        origin_z: 0.0
        z_resolution: 0.05
        z_voxels: 16
        mark_threshold: 0
        scan:
          clearing: True
          marking: True
          raytrace_max_range: 3.0
          raytrace_min_range: 0.0
          obstacle_max_range: 2.5
          obstacle_min_range: 0.0
      static_layer:
        map_subscribe_transient_local: True
      always_send_full_costmap: True
  local_costmap_client:
    ros__parameters:
      use_sim_time: False
  local_costmap_rclcpp_node:
    ros__parameters:
      use_sim_time: False
global_costmap:
  global_costmap:
    ros__parameters:
      resolution: 0.05
      origin_x: -25.0
      origin_y: -25.0
      update_frequency: 1.0
      publish_frequency: 1.0
      global_frame: "map"
      use_sim_time: False
      robot_radius: 0.1
      resolution: 0.05
      track_unknown_space: true
      map_topic: "/map"
      use_namespace: False
      plugins: ["static_layer", "obstacle_layer", "voxel_layer", "inflation_laye
r"]
      obstacle_layer:
        enabled: True
        scan:
          clearing: True
          marking: True
      voxel_layer:
        enabled: True
        origin_z: 0.0
        z_resolution: 0.05
        z_voxels: 16
        mark_threshold: 0
        scan:
          clearing: True
          marking: True
      static_layer:
        plugin: "nav2_costmap_2d::StaticLayer"
      inflation_layer:
        inflation_radius: 0.55
  global_costmap_client:
    ros__parameters:
      use_sim_time: False
  global_costmap_rclcpp_node:
    ros__parameters:
      use_sim_time: False
map_server:
  ros__parameters:
    use_sim_time: False
    yaml_filename: ""
#map_saver:
#  ros__parameters:
#    use_sim_time: False
#    save_map_timeout: 5.0
#    free_thresh_default: 0.25
#    occupied_thresh_default: 0.65
#    map_subscribe_transient_local: True
planner_server:
  ros__parameters:
    expected_planner_frequency: 20.0
    use_sim_time: False
    planner_plugins: ["GridBased"]
    GridBased:
      plugin: "nav2_navfn_planner/NavfnPlanner"
      tolerance: 0.5
      use_astar: true
      allow_unknown: true
planner_server_rclcpp_node:
  ros__parameters:
    use_sim_time: False
recoveries_server:
  ros__parameters:
    costmap_topic: local_costmap/costmap_raw
    footprint_topic: local_costmap/published_footprint
    cycle_frequency: 10.0
    recovery_plugins: ["spin", "backup", "wait"]
    spin:
      plugin: "nav2_recoveries/Spin"
    backup:
      plugin: "nav2_recoveries/BackUp"
    wait:
      plugin: "nav2_recoveries/Wait"
    transform_timeout: 0.1
    use_sim_time: true
    simulate_ahead_time: 2.0
    max_rotational_vel: 1.0
    min_rotational_vel: 0.4
    rotational_acc_lim: 3.2
robot_state_publisher:
  ros__parameters:
    use_sim_time: False
waypoint_follower:
  ros__parameters:
    loop_rate: 2000
    stop_on_failure: false
    waypoint_task_executor_plugin: "wait_at_waypoint"
    wait_at_waypoint:
      plugin: "nav2_waypoint_follower::WaitAtWaypoint"
      enabled: True
      waypoint_pause_duration: 200
