ROS Prerequisites Exam Certificate
I have finisehd the Code Foundation for ROS and the result for the Prerequisites Exam is 9/10 as shown below. However, I haven’t received the certifcate yet. Could you please help? Thank you in advance.
As the image indicates, your grading did not complete successfully (even if you scored 9.00) - it timed out, because there was a problem with a part of your code.
The error indicated (code taking too long to run or infinite loops) is very critical and must not happen in production code, so we need to resolve it.
Please fix the error indicated and try again.
For solving this issue, please have a look at the test recommended here:
