Hi the construct team I hope all are fine,
I am a beginner in Ros2 and I am struggled for more than 1 week working on the real robot project part 1 the wall following behavior I wrote my code and I am sure that it is correct but it dose not work so I would appreciate if you can tell me where is the mistake or what should I do if my code is not correct.
this is the code of wall_following.py :
import rclpy
from rclpy.node import Node
class WallFollower(Node):
super().__init__('wall_follower')
self.publisher_ = self.create_publisher(Twist, '/cmd_vel', 10)
self.subscription_ = self.create_subscription(
LaserScan,
'/scan',
self.laser_callback,
10
self.wall_distance_ = 0.3
self.front_wall_distance_ = 0.5
ranges = msg.ranges
right_ray_index = int(len(ranges) * 3 / 4) # Index of the rightmost laser ray
front_ray_index = int(len(ranges) / 2) # Index of the laser ray in front of the robot
# Check if there is a wall in front
if ranges[front_ray_index] < self.front_wall_distance_:
self.update_velocity(0.0, 0.45) # Turn fast to the left
return
# Calculate the distance to the wall on the right
right_distance = ranges[right_ray_index]
# Adjust the linear and angular velocities based on the distance to the wall
if right_distance > self.wall_distance_ + 0.05:
self.update_velocity(0.15, -0.45) # Approach the wall
elif right_distance < self.wall_distance_ - 0.05:
self.update_velocity(0.15, 0.45) # Move away from the wall
else:
self.update_velocity(0.15, 0.0) # Maintain the current distance
def update_velocity(self, linear, angular):
# Create a Twist message with the provided linear and angular velocities
msg = Twist()
msg.linear.x = linear
msg.angular.z = angular
self.publisher_.publish(msg)
def main(args=None):
rclpy.init(args=args)
wall_follower = WallFollower()
rclpy.spin(wall_follower)
wall_follower.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
I will appreciate your help ![]()
Best Regards,
Ghassan
