Hi the construct team I hope all are fine,
I am a beginner in Ros2 and I am struggled for more than 1 week working on the real robot project part 2 the find wall behavior I wrote my code and I am sure that it is correct but it dose not work so I would appreciate if you can tell me where is the mistake or what should I do if my code is not correct the problem or issue is that the robot is not aligned to the right wall
this is the code of wall_finder.py :
from rclpy.callback_groups import ReentrantCallbackGroup
from custom_interfaces.srv import FindWall
import rclpy
from rclpy.node import Node
import numpy as np
import time
class WallFinderServer(Node):
super().__init__('wall_finder_server')
self.group = ReentrantCallbackGroup()
self.wall_finder_srv = self.create_service(
FindWall,
"find_wall",
self.find_wall_callback,
callback_group=self.group)
self.twist_publisher = self.create_publisher(
Twist,
"cmd_vel",
10,
self.sub_laser = self.create_subscription(
LaserScan,
"scan",
self.laser_callback,
QoSProfile(depth=10, reliability=ReliabilityPolicy.BEST_EFFORT),
self.initial_configuration = False
self.turn_sign = +1
self.laser_min_idx = 0
self.laser_min = -1.0
self.angle_to_rotate = 0.0
self.laser_front = 0.0
self.n_ranges = 0.0
self.front_laser_idx = 0
self.right_laser_idx = 0
self.dist_tol = 0.03
self.laser_idx_tol = 6
self.vel_angular_z = 0.2
self.vel_linear_x = 0.05
self.first_turn_finished = False
self.second_turn_finished = False
if not self.initial_configuration:
self.n_ranges = round((2 * np.pi / msg.angle_increment) + 1)
self.front_laser_idx = int(self.n_ranges/2)
self.right_laser_idx = int(self.n_ranges/4)
self.initial_configuration = True
self.get_logger().info('Front laser idx: "%s"' % str(self.front_laser_idx))
self.get_logger().info('Right laser idx: "%s"' % str(self.right_laser_idx))
self.laser_min_idx = np.argmin(msg.ranges[:])
self.laser_min = msg.ranges[self.laser_min_idx]
min_range_angle = (2 * np.pi * (self.laser_min_idx + 1)) / self.n_ranges
if not self.first_turn_finished:
self.angle_to_rotate = min_range_angle - np.pi
if self.angle_to_rotate < 0:
self.turn_sign = -1
self.get_logger().info('Angle to rotate: "%s"' % str(self.angle_to_rotate * 180 / np.pi))
elif not self.second_turn_finished:
self.angle_to_rotate = min_range_angle - np.pi/2
self.get_logger().info('Angle to rotate 2: "%s"' % str(self.angle_to_rotate * 180 / np.pi))
# self.get_logger().info('Angle to rotate: "%s"' % str(self.laser_min_idx ))
self.laser_front = msg.ranges[self.front_laser_idx]
def find_wall_callback(self, request, response):
msg = Twist()
while (self.laser_min < 0):
self.get_logger().info('WAITING FOR IDENTIFYING THE NEAREST WALL')
time.sleep(0.5)
while (abs(self.laser_min_idx - self.front_laser_idx) > self.laser_idx_tol):
msg.angular.z = self.turn_sign * self.vel_angular_z
self.twist_publisher.publish(msg)
time.sleep(0.5)
self.get_logger().info('FIRST TURN')
self.first_turn_finished = True
msg.angular.z = 0.0
self.get_logger().info('First turn finished, the robot is looking the nearest wall')
linear_x_sign = 1
if self.laser_front < 0.3:
linear_x_sign = -1
while abs(self.laser_front - 0.3) > self.dist_tol:
msg.linear.x = linear_x_sign * self.vel_linear_x
msg.angular.z = 0.0
time.sleep(0.5)
self.get_logger().info('LINEAR MOTION')
msg.linear.x = 0.0
self.get_logger().info('The robot 30 cm away from the wall')
while (abs(self.laser_min_idx - self.right_laser_idx) > self.laser_idx_tol):
msg.angular.z = self.vel_angular_z
time.sleep(0.5)
self.get_logger().info('SECOND TURN')
self.second_turn_finished = True
msg.angular.z = 0.0
self.get_logger().info('The robot is aligned with the right wall')
response.wallfound = True
return response
def main(args=None):
rclpy.init(args=args)
wall_finder_node = WallFinderServer()
# Create a MultiThreadedExecutor with 3 threads
executor = MultiThreadedExecutor(num_threads=3)
# Add the node to the executor
executor.add_node(wall_finder_node)
try:
# Spin the executor
executor.spin()
finally:
# Shutdown the executor
executor.shutdown()
wall_finder_node.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
I hope you can help me ![]()
Best Regards,
Ghassan
