I am literally just following the tutorial as titled above and am stuck. I have managed to spawn an object that I want to view in rviz2.
I have included parameters
/wrist_rgbd/depth/camera_info/wrist_rgbd/depth/points
then launched them:
cd ~/catkin_ws
catkin_make
source devel/setup.bash
then run the bridge:
source /home/simulations/ros2_sims_ws/install/setup.bash
ros2 run ros1_bridge parameter_bridge __name:=parameter_bridge
but when I run:
rviz2
No object is seen like it is in gazebo, and though I can see both new parameters in the ros2 list, rviz2 shows nothing and also gives the error “Global Status Warning - fixed frame - no tf data - actual error: Frame[map does not…]”
I think I have followed the tutorial to the letter… but still this error! Any help please?
