Hello guys,
I run this lesson (ROS2 Navigation in 5 days) until Section 6. Then I worked on a rosject to complete the requested task.
I didn’t work on the course for about 10 days and now that I come back to Section 6 to complete it nothing is working.
First of all I tried to run some basic mapping functionality to get started but I couldn’t run it, I got these errors:
[INFO] [occupancy_grid_node-2]: process started with pid [5834]
[cartographer_node-1] /opt/ros/galactic/lib/cartographer_ros/cartographer_node: symbol lookup error: /opt/ros/galactic/lib/cartographer_ros/cartographer_node: undefined symbol: _ZN7tf2_ros6BufferC1ESt10shared_ptrIN6rclcpp5ClockEENSt6chrono8durationIlSt5ratioILl1ELl1000000000EEEES1_INS2_4NodeEE
[ERROR] [cartographer_node-1]: process has died [pid 5832, exit code 127, cmd '/opt/ros/galactic/lib/cartographer_ros/cartographer_node -configuration_directory /home/user/ros2_ws/install/cartographer_slam/share/cartographer_slam/config -configuration_basename cartographer.lua --ros-args -r __node:=cartographer_node --params-file /tmp/launch_params_mb3x9u2g'].
I couldn’t even run the rviz2, the error with rviz2 was that it couldn’t find the package rviz_common “ros2 package ‘rviz_common’ not found”.
Then I went to Section 1 to see if there is any setup that needed to be done in the first place (which there were).
After running all the steps, on the last step where I run “ros2 launch nav2_course nav2_demo.launch.py nav2_demo.launch” it doesn’t work either, it gives these errors:
[lifecycle_manager-4] [INFO] [1674292855.302889876] [lifecycle_manager_localization]: Configuring amcl
[rviz2-1] [rospack] Error: package 'rviz_common' not found
[rviz2-1] [librospack]: error while executing command
[rviz2-1] [INFO] [1674292855.473521591] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-1] [INFO] [1674292855.473670030] [rviz2]: OpenGl version: 3.1 (GLSL 1.4)
[rviz2-1] [INFO] [1674292855.538105902] [rviz2]: Stereo is NOT SUPPORTED
[rviz2-1] rviz2: malloc.c:2379: sysmalloc: Assertion `(old_top == initial_top (av) && old_size == 0) || ((unsigned long) (old_size) >= MINSIZE && prev_inuse (old_top) && ((unsigned long) old_end & (pagesize - 1)) == 0)' failed.
[ERROR] [rviz2-1]: process has died [pid 2088, exit code -6, cmd '/opt/ros/galactic/lib/rviz2/rviz2 -d /opt/ros/galactic/share/nav2_bringup/rviz/nav2_default_view.rviz --ros-args'].
[INFO] [lifecycle_manager-10]: sending signal 'SIGINT' to process[lifecycle_manager-10]
[INFO] [waypoint_follower-9]: sending signal 'SIGINT' to process[waypoint_follower-9]
[INFO] [lifecycle_manager-4]: sending signal 'SIGINT' to process[lifecycle_manager-4]
[INFO] [map_server-2]: sending signal 'SIGINT' to process[map_server-2]
[lifecycle_manager-10] [INFO] [1674292855.770951243] [rclcpp]: signal_handler(signal_value=2)
[lifecycle_manager-10] terminate called after throwing an instance of 'std::runtime_error'
[lifecycle_manager-10] what(): controller_server/change_state service client: interrupted while waiting for service
[waypoint_follower-9] [INFO] [1674292855.776586549] [rclcpp]: signal_handler(signal_value=2)
[waypoint_follower-9] [INFO] [1674292855.778748838] [waypoint_follower]: Destroying
[lifecycle_manager-4] [INFO] [1674292855.779398505] [rclcpp]: signal_handler(signal_value=2)
[lifecycle_manager-4] terminate called after throwing an instance of 'std::runtime_error'
[lifecycle_manager-4] what(): amcl/change_state service client: interrupted while waiting for service
[map_server-2] [INFO] [1674292855.784102541] [rclcpp]: signal_handler(signal_value=2)
[map_server-2] [INFO] [1674292855.789112550] [map_server]: Destroying
[ERROR] [lifecycle_manager-10]: process has died [pid 2106, exit code -6, cmd '/opt/ros/galactic/lib/nav2_lifecycle_manager/lifecycle_manager --ros-args -r __node:=lifecycle_manager_navigation --params-file /tmp/launch_params_7pdaq4c6 --params-file /tmp/launch_params__wfc50_c --params-file /tmp/launch_params_smxogy4q'].
[ERROR] [lifecycle_manager-4]: process has died [pid 2094, exit code -6, cmd '/opt/ros/galactic/lib/nav2_lifecycle_manager/lifecycle_manager --ros-args -r __node:=lifecycle_manager_localization --params-file /tmp/launch_params_ll93htej --params-file /tmp/launch_params_1sgzqmx_ --params-file /tmp/launch_params__y0qo_ng'].
[INFO] [waypoint_follower-9]: process has finished cleanly [pid 2104]
[INFO] [map_server-2]: process has finished cleanly [pid 2090]
I guess something is going wrong with my environment and I have no idea how this can be fixed…
Do you have any suggestions?
Thank you for in advance.
