I am working on the ROS2 Navigation Rosject, Section 3 Path Planning.
After launching my pathplanner.launch.py launch file, I get the following repeated warnings:
[controller_server-5] [WARN] [1674112988.556317739] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112988.756970089] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112988.957115772] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112989.156317801] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112989.356843994] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112989.558379535] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112989.759332438] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112989.956379915] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112990.156456703] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112990.356406889] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112990.556508686] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
[controller_server-5] [WARN] [1674112990.756434723] [LifecyclePublisher]: Trying to publish message on the topic '/local_costmap/clearing_endpoints', but the publisher is not activated
Launch file content highlights:
map_server, amcl, lifecycle_manager_localization for map_server and amcl
planner, controller, recoveries, bt_navigator and lifecycle_manager_pathplanning for the previous 4 nodes.
I have no idea what to do to get rid of this. All I can understand is that /local_costmap/clearing_endpoints should publish something but it is not publishing it, because some process that needs to “activate” the publisher did not happen.
I have not worked on the real robot yet - I am still working on the simulation and getting this error / warning.
Please help / advice.
Thanks,
Hi @girishkumar.kannan,
it think that this is probably because when you use Lifecycle Nodes, a publisher must be activated in order to enable publishing.
To do so you must call the publishers on_activate() method inside the implementation of the LifecycleNode on_activate() method.
Like this:
rclcpp_lifecycle::node_interfaces::LifecycleNodeInterface::CallbackReturn
on_activate(const rclcpp_lifecycle::State &)
pub_->on_activate();
return rclcpp_lifecycle::node_interfaces::LifecycleNodeInterface::CallbackReturn::SUCCESS;
Is this implemented in your code?
Cheers,
Roberto
Hi @rzegers ,
Thanks for your quick reply.
I searched Google and found a similar answer. But the problem is, I have no idea where to make this modification. I do not have any cpp files in any of my ros2 package.
I think this must be done in the library files, which again, I have no idea which file to open and modify.
Thanks,
yes, my answer applies in the general case when you create your own managed node so that you know that the publisher gets activated when the node transitions to the activated state. I am pretty sure in Nav2 that is already implemented. So now you can find out what the current state of that node is. From the logger I see that the node name must be controller_server (but you can confirm that with ros2 node list) so the command would be:
ros2 lifecycle get controller_server
And also find out what the possible states for that node are:
ros2 lifecycle list controller_server -a
The next step would be to try to execute a state change and get to the activated state, which should activate the publisher and get rid of that message.
Cheers,
Roberto
Hi @rzegers ,
Tried the above two commands, here are my outputs:
user:~$ ros2 lifecycle get
--include-hidden-nodes
--no-daemon
--spin-time
/amcl
/amcl_rclcpp_node
/bt_navigator
/bt_navigator_rclcpp_node
/controller_server
/controller_server_rclcpp_node
/lifecycle_manager_localization
/lifecycle_manager_localization_service_client
/local_costmap/local_costmap
/local_costmap/local_costmap_rclcpp_node
/local_costmap_client
/ros_bridge
/rviz
/transform_listener_impl_559ee276d5e0
/transform_listener_impl_55ef4c4abe50
/transform_listener_impl_564735a0bd30
user:~$ ros2 lifecycle get /controller_server
active [3]
user:~$ ros2 lifecycle get /controller_server_rclcpp_node
Node not found
user:~$ ros2 lifecycle list /controller_server -a
- configure [1]
Start: unconfigured
Goal: configuring
- transition_success [10]
Start: configuring
Goal: inactive
- transition_failure [11]
Start: configuring
Goal: unconfigured
- transition_error [12]
Start: configuring
Goal: errorprocessing
- cleanup [2]
Start: inactive
Goal: cleaningup
- transition_success [20]
Start: cleaningup
Goal: unconfigured
- transition_failure [21]
Start: cleaningup
Goal: inactive
- transition_error [22]
Start: cleaningup
- activate [3]
Start: inactive
Goal: activating
- transition_success [30]
Start: activating
Goal: active
- transition_failure [31]
Start: activating
Goal: inactive
- transition_error [32]
Start: activating
- deactivate [4]
Start: active
Goal: deactivating
- transition_success [40]
Start: deactivating
Goal: inactive
- transition_failure [41]
Start: deactivating
Goal: active
- transition_error [42]
Start: deactivating
- shutdown [5]
Start: unconfigured
Goal: shuttingdown
- shutdown [6]
Start: inactive
Goal: shuttingdown
- shutdown [7]
Start: active
Goal: shuttingdown
- transition_success [50]
Start: shuttingdown
Goal: finalized
- transition_failure [51]
Start: shuttingdown
Goal: finalized
- transition_error [52]
Start: shuttingdown
- transition_success [60]
Start: errorprocessing
Goal: unconfigured
- transition_failure [61]
Goal: finalized
- transition_error [62]
Goal: finalized
user:~$ ros2 lifecycle list /controller_server_rclcpp_node -a
Node not found
user:~$
– Girish
Hi @rzegers ,
Quick Update: I followed this post and got my path planning to work. When I had this warning, my robot never moved. Now it reaches the goal pose.
But I still keep getting this warning continuously printed.
I do not mind this warning, now that my robot moves to the goal pose. But it keeps spamming my terminal, which annoys me a little.
Is there a way to stop the warning?
– Girish
So this happens because the course shows config files for Nav2 for Galactic, but the rosject runs on Nav2 for Foxy? I see, thanks for reporting!
From your output of ros2 lifecycle get /controller_server I see that the state is already active, in that case it is very strange that you have that warnings printed out… at the moment I am out of ideas, this probably requires deeper research …
