Is it still possible to add .stl meshes to ros2 urdf as in ros1? The problem I am having right now is I have a working urdf model ( which uses .stl files) in ros1 but when I brought the exact same model to Ros2, I do not see anything in rviz2. Is there anything that I need to change?
Thank you for your help!
