Hi!
I am trying to get an octomap using Rtabmap. As instructed in the Rtabmap documentation, this is done automatically if Rtabmap_ros is built with Octomap.
I tried to so by adding this into the CMakeLists.txt file of Rtabmap_ros:
find_package(octomap_msgs)
find_package(octomap REQUIRED)
include_directories(${OCTOMAP_INCLUDE_DIRS})
link_libraries(${OCTOMAP_LIBRARIES})
And also this into the Package.xml:
<build_depend>octomap</build_depend>
<build_depend>octomap_msgs</build_depend>
<exec_depend>octomap</exec_depend>
<exec_depend>octomap_msgs</exec_depend>
When building again the package I get the following warning:
CMake Warning at CMakeLists.txt:496 (add_executable):
Cannot generate a safe runtime search path for target
rtabmap_pointcloud_to_depthimage because files in some directories may
conflict with libraries in implicit directories:
runtime library [liboctomap.so.1.9] in /usr/lib/x86_64-linux-gnu may be hidden by files in:
/opt/ros/galactic/lib
runtime library [liboctomath.so.1.9] in /usr/lib/x86_64-linux-gnu may be hidden by files in:
Some of these libraries may not be found correctly.
However, if I build it again, the warning disappears. The problem is that although the /octomap_full topic is being published, its data is empty…
Can anybody help me? I need this done for an important project
