[RVIz2 and Gazebo] Tiny Windows
I am working on Checkpoint 12 of the Advanced Navigation course.
Having the same problems as mentioned herewith Gazebo and RViz2.
Tried logging in and out, neither scrolling nor the following help:
sudo update
sudo apt install xterm
xterm -geometry 80x24+0+0 -e rviz2
The displays have been working well up till this morning.
Any advice would be appreciated.
[UPDATE] I was using Firefox when the above occurred. The problem does not occur when I switch to Chrome.
Thanks.
Thanks for letting us know it worked with Chrome. However, it should also work fine on Firefox.
Also, please note that you don’t need to install anything to make the windows work properly.
Hi @samcly374 ,
Do you have Quillbot extension in the browser that the problem happens?
Someone already reported this error before, and we found that disabling Quillbot and reloading the page solved the problem, as we can see in the link below:
