Services quiz custom message
Hello everyone
I have a easy problem but I don’t know why I can’t fix it, I was trying to solve it for hours.
I want to create a custom message but I can’t run the python file due to the error it show on the line
“from services_quiz.srv import BB8CustomServiceMessage, BB8CustomServiceMessageResponse”
attached is the related part.
the error says : "Unable to import ‘services_quiz.srv’ "
but I already defined the package
even when I search the service it shows ---->
user:~/catkin_ws$ rossrv list | grep BB8CustomServiceMessage
services_quiz/BB8CustomServiceMessage
Hi @ptgh
First of all, Make sure that you have Compiled using catkin_make and sourced the work after compilation.
If the error still persist, can you share the following:
1.The BB8CustomServiceMessage.srv file you created
2.The changes made in CMake file
3.The changes made in Package.xml file.
4.Confirm that the package containing the newly created service message and the python file you created are the same.
5. Share the python file you created.
Share the result for the following command (after catkin_make ofcourse)
6. rossrv list | grep BB8
(above command will tell us if the service message is registered with ROS
7. rosservice list | grep
Welcome to the community :grinning:
I compiled it with catkin_make previously but the problem persist.
here is the The BB8CustomServiceMessage.srv file:
float64 side # The distance of each side of the square
int32 repetitions # The number of times BB-8 has to execute the square movement when the service is called
bool success # Did it achieve it?
CMake file:
project(services_quiz)
rospy
std_msgs
message_generation
roscpp
add_service_files(
FILES
generate_messages(
DEPENDENCIES
std_msgs
catkin_package(
CATKIN_DEPENDS rospy
include_directories(
include
${catkin_INCLUDE_DIRS}
Package.xml file:
<?xml version="1.0"?>
services_quiz
0.0.0
The services_quiz package
user
TODO
I could not underestand number 4.
Python file:
  1. user:~$ rossrv list | grep BB8
thank you for you help.
Hi @ptgh , i will try to go thorugh the data you shared, but can you send the same data again using image from
This is used to display the code , instead of opting to copy paste directly which gives code within random fonts and random indents.
Just click on image and then copy the code you want to share in it.
This will make
Look like below, much easier to understand right?
Corrections:
From based on what i can see,
  • I think you missed the 3 dashes (no spaces) between request and response, it should look like below:
Correction in Cmake:
rosccp not required since we are using any C++ files
  std_msgs
  message_generation
add message_runtime
catkin_package(
      CATKIN_DEPENDS
      rospy message_runtime
Let me know if the changes made any difference
Hey, thank you for your guide,
I made the changes and still same error, I will attach the code and files based on what you mentioned.
CMake file:
  rospy
  std_msgs
  message_generation
 add_service_files(
   FILES
 generate_messages(
   DEPENDENCIES
   std_msgs
catkin_package(
  CATKIN_DEPENDS
# include
## Declare a C++ library
# add_library(${PROJECT_NAME}
#   src/${PROJECT_NAME}/services_quiz.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/services_quiz_node.cpp)
#   ${catkin_LIBRARIES}
## Install ##
#   scripts/my_python_script
#   DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
#   DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
#   FILES_MATCHING PATTERN "*.h"
#   PATTERN ".svn" EXCLUDE
# install(FILES
#   # myfile1
#   # myfile2
#   DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_services_quiz.cpp)
#   target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
# endif()
# catkin_add_nosetests(test)
Package.xml file:
<package format="2">
  <name>services_quiz</name>
  <version>0.0.0</version>
  <description>The services_quiz package</description>
  <!-- Example:  -->
  <!--   BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
  <license>TODO</license>
  <!-- Example: -->
  <!-- <url type="website">http://wiki.ros.org/services_quiz</url> -->
  <!-- Example: -->
  <!-- Examples: -->
  <!--   <depend>roscpp</depend> -->
  <!--   Note that this is equivalent to the following: -->
  <!--   <build_depend>roscpp</build_depend> -->
  <!--   <exec_depend>roscpp</exec_depend> -->
  <!--   <build_depend>message_generation</build_depend> -->
  <!--   <build_export_depend>message_generation</build_export_depend> -->
  <!--   <buildtool_depend>catkin</buildtool_depend> -->
  <!--   <exec_depend>message_runtime</exec_depend> -->
  <!--   <test_depend>gtest</test_depend> -->
  <!--   <doc_depend>doxygen</doc_depend> -->
  <export>
  </export>
</package>
the package of python file and the message are the same.
Python file:
def my_callback(request):
    cmd.linear.x = 0.3
    cmd.angular.z = 0.31
    cmd.linear.y = 0.3
    cmd.linear.x = -0.3
    cmd.linear.y = -0.3
    r= 0
    while r <= request.repetitions :
         pub.publish(cmd)
         rate.sleep()
         r=r+1
    cmd.linear.x = 0
    cmd.linear.y = 0
    cmd.angular.z = 0
    pub.publish(cmd)
    response.success = True
    return response # the service Response class, in this case EmptyResponse
rospy.init_node('service_move_bb8_in_square_custom_server')
my_service = rospy.Service('/move_bb8_in_square_custom', BB8CustomServiceMessage, my_callback)
response = BB8CustomServiceMessageResponse()
#pub2 = rospy.Publisher('/counter', Int32, queue_size=1)
cmd= Twist()
#count=Int32()
rate = rospy.Rate(5)
thank you in advance.
I tried the content based on the code you provided as is and did not get any errors regarding the service messages.
Most errors happen due to improper compilation,so compile using below cmds.
cd catkin_ws
catkin_make
source devel/setup.bash
during compilation check for any errors in that web shell
Anyways, the error i did see in you code is as follows:
   cmd.linear.x = 0.3
    cmd.linear.y = 0.3
    cmd.linear.x = -0.3
    cmd.linear.y = -0.3
    r= 0
         pub.publish(cmd)
         rate.sleep()
         r=r+1
You see ,here cmd.linear.x = 0.3, changes to cmd.linear.x = -0.3, the value gets updated to the new value you assigned and 0.3 is ignored. this error is repeated for all the values of x, y and z. You need to publish the values using pub.Publish() else there is nothing happening with the value you assigned.
Also, to move linearly, you only need to make changes in X, and Z is to be used only when you need it to rotate there is no need for Y.
In the case, above, unless you mentioned pub.publish(cmd) every time, only the very last values of x=-0.3 and Z=0.31 will be published. You also need to tell how long you want a command to run using rospy.sleep(time in secs). everytime.
The correct way is as follows:
    print("callback called")
    r=0
        #move forward
        print("moving forward")
        cmd.linear.x=0.2
        cmd.angular.z=0
        pub.publish(cmd)
        rospy.sleep(2)
        #stop
        print("stop")
        cmd.linear.x=0
        cmd.angular.z=0
        pub.publish(cmd)
        rospy.sleep(2)
        #rotate
        print("Rotate")
        cmd.linear.x=0
        cmd.angular.z=0.2
        pub.publish(cmd)
        #modify the time 2 below to till the right angle rotation is achived
        rospy.sleep(2)
        #stop
        print("stop")
        cmd.linear.x=0
        cmd.angular.z=0
        pub.publish(cmd)
        rospy.sleep(2)
        #update r
        r=r+1
PLEASE note that the above code is only to show that the robot can move forward and rotate based on the code and not the complete solution. Since this is a quiz, i can’t reveal everything at the start, but if you are stuck, I will definitely help out.
You still need to modify the code to make the robot rotate at right angle by tweaking the rospy.sleep(modify_value) and modifying the cmd.linear,x value and corresponding rospy.sleep() values to make sure that the distance traveled is based on the side value provided.
The python file
    r=0
        #move forward
        cmd.linear.x=0.2
        cmd.angular.z=0
        pub.publish(cmd)
        rospy.sleep(2)
        #stop
        print("stop")
        cmd.linear.x=0
        cmd.angular.z=0
        pub.publish(cmd)
        rospy.sleep(2)
        #rotate
        print("Rotate")
        cmd.linear.x=0
        cmd.angular.z=0.2
        pub.publish(cmd)
        rospy.sleep(2)
        #stop
        print("stop")
        cmd.linear.x=0
        cmd.angular.z=0
        pub.publish(cmd)
        rospy.sleep(2)
        #update r
        r=r+1
while pub.get_num_connections()<1:
    pass
cmd= Twist()
#count=Int32()
rospy.spin()
All the other files remain unchanged.
Let me know if this solution worked out, (just in case, why dont you start over with a fresh package, while deleting the previous package in case the error persists)
Hey
Many thanks, I changed my program and fixed the issues you mentioned, it is working now.
Glad it was helpful, do reach out in the future :grinning:
(Do mark solution checkbox in this page to close this topics now that we have found the solution)
Hello sir.
I am trying to solve the quiz since many days, yet the service is not starting so that i can call it. My python code is –
def callback (request):
    distance = request.side
    i=0
    while i< request.repetitions:
        j=0
        while j < 4:
            move.linear.x = 0.3
            move.angular.z = 0.0
            pub.publish(move)
            rospy.sleep(distance)
            move.linear.x = 0.0
            pub.publish(move)
            rospy.sleep(1)
            move.linear.x = 0.0
            move.angular.z = 0.1
            pub.publish(move)
            rospy.sleep(1.5)
            move.linear.x = 0.0
            pub.publish(move)
            rospy.sleep(0.5)
            j+=1
        move.linear.x = 0.0
        move.angular.z=0.0
        pub.publish(move)
        i+=1
    move.linear.x=0.0
    move.angular.z=0.0
    pub.publish(move)
    return response
rospy.init_node('services_quiz_node')
move_bb8_in_square_custom = rospy.Service('/move_bb8_in_square_custom',BB8CustomServiceMessage, callback)
pub = rospy.Publisher('/cmd_vel',Twist,queue_size=1)
move=Twist()
I try to run the python file by –
rosrun services_quiz bb8_move_custom_service_server.py
But output is nothing (as shown in screenshot below) –
It would be of great help if you can plz tell where am i going wrong here.
add rospy.spin() at the end of the code. This will keep the program from exiting once it reaches the last line of code. Try this and see if there are any changes.
    i=0
        j=0
        while j < 4:
            move.linear.x = 0.3
            pub.publish(move)
            move.linear.x = 0.0
            pub.publish(move)
            rospy.sleep(1)
            move.linear.x = 0.0
            pub.publish(move)
            rospy.sleep(1.5)
            move.linear.x = 0.0
            pub.publish(move)
            rospy.sleep(0.5)
            j+=1
        move.linear.x = 0.0
        move.angular.z=0.0
        pub.publish(move)
        i+=1
    move.linear.x=0.0
    move.angular.z=0.0
    pub.publish(move)
    return response
move=Twist()
rospy.spin()
Thank you so much sir !! It worked successfully finally !! Actually I read this statement (screenshot attached) and didn’t write rospy.spin().
tips
I didn’t understand that this tip is for the client file, not server file. Thanks again!
A post was split to a new topic: Stuck on the service quiz
