Hello, i was confused about the instruction, but i’d found the solution so i’ve done the course.
Maybe it can help anyone that confused too.
in start_amcl_localization.launch :
<param name="odom_frame_id" value="odom"/> <param name="base_frame_id" value="base_footprint"/> <param name="global_frame_id" value="map"/>
change to
<param name="odom_frame_id" value="summit_xl_a_odom"/> <param name="base_frame_id" value="summit_xl_a_base_link"/> <param name="global_frame_id" value="map"/>
in move_base_map.launch:
**add this three line after
<node pkg="move_base" type="move_base" respawn="false" name="move_base" output="screen">
<remap from="scan" to="/hokuyo_base/scan" /> <remap from="cmd_vel" to="/summit_xl_control/cmd_vel"/> <remap from="odom" to="/odometry/filtered" />
I hope the instruction on notebook can be updated too ![]()
