hi
trying to spawn urdf model in gazebo (unit 2)
launch file is
<?xml version="1.0" encoding="UTF-8"?>
<launch>
<arg name="x" default="0.0" />
<arg name="y" default="0.0" />
<arg name="z" default="0.0" />
<arg name="urdf_robot_file" default="" />
<arg name="robot_name" default="" />
<!-- This Version was created due to some errors seen in the V1 that crashed GAzebo or went too slow in spawn -->
<!-- Load the URDF into the ROS Parameter Server -->
<param name="robot_description" command="cat $(arg urdf_robot_file)" />
<!-- Run a python script to the send a service call to gazebo_ros to spawn a URDF robot -->
<node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen"
args="-urdf -x $(arg x) -y $(arg y) -z $(arg z) -model $(arg robot_name) -param robot_description"/>
</launch>
<launch>
<include file="$(find my_mira_description)/launch/spawn_urdf.launch">
<arg name="x" value="0.0" />
<arg name="y" value="0.0" />
<arg name="z" value="0.2" />
<arg name="urdf_robot_file" value="$(find my_mira_description)/urdf/mira_simple_collisions_inertias.urdf" />
<arg name="robot_name" value="mira" />
</include>
</launch>
urdf file
<?xml version="1.0"?>
<!-- * * * Link Definitions * * * -->
<link name="base_link">
<inertial>
<mass value="0.18" />
<inertia ixx="0.0002835" ixy="0.0" ixz="0.0" iyy="0.0002835" iyz="0.0" izz="0.000324"/>
</inertial>
<collision>
<geometry>
<cylinder radius="0.06" length="0.09"/>
</geometry>
</collision>
<visual>
<origin rpy="0 0 0" xyz="0 0 0"/>
<geometry>
</geometry>
</visual>
</link>
<gazebo reference="base_link">
<kp>100000.0</kp>
<kd>100000.0</kd>
<mu1>10.0</mu1>
<mu2>10.0</mu2>
<material>Gazebo/Grey</material>
</gazebo>
I’m getting an error
roslaunch my_mira_description spawn_mira_simple_collisions_inertias.launch
... logging to /home/user/.ros/log/d46b8816-266c-11ec-b15c-0242c0a81006/roslaunch-2_xterm-7422.log
Press Ctrl-C to interrupt
started roslaunch server http://2_xterm:32983/
SUMMARY
PARAMETERS
* /robot_description: <!-- * * * Link D...
* /rosdistro: kinetic
* /rosversion: 1.12.14
NODES
urdf_spawner (gazebo_ros/spawn_model)
ROS_MASTER_URI=http://2_simulation:11311
process[urdf_spawner-1]: started with pid [7432]
SpawnModel script started
[INFO] [1633503496.174905, 0.000000]: Loading model XML from ros parameter
[INFO] [1633503496.176653, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[INFO] [1633503496.179223, 0.000000]: Calling service /gazebo/spawn_urdf_model
Service call failed: service [/gazebo/spawn_urdf_model] responded with an error:
[urdf_spawner-1] process has finished cleanly
log file: /home/user/.ros/log/d46b8816-266c-11ec-b15c-0242c0a81006/urdf_spawner-1*.log
What can be the problem?
thanks
