Trying unit 6 of ROS2 RMF course on real robots
i am trying to use code similar to unit 6 to realise rmf with my physical robot(s). this is the error i am getting when i run the fleet adapter.
Starting fleet adapter…
[INFO] [1738744154.948739359] [originbot_fleet_adapter]: Parameter [discovery_timeout] set to: 60.000000
File “/home/fyp2024/rmf_ws/install/physical_api/lib/physical_api/fleet_adapter”, line 33, in
sys.exit(load_entry_point(‘physical-api==0.0.0’, ‘console_scripts’, ‘fleet_adapter’)())
File “/home/fyp2024/rmf_ws/install/physical_api/lib/python3.10/site-packages/physical_api/fleet_adapter.py”, line 314, in main
adapter = initialize_fleet(
File “/home/fyp2024/rmf_ws/install/physical_api/lib/python3.10/site-packages/physical_api/fleet_adapter.py”, line 87, in initialize_fleet
assert adapter, ("Unable to initialize fleet adapter. Please ensure "
AssertionError: Unable to initialize fleet adapter. Please ensure RMF Schedule Node is running
[ros2run]: Process exited with failure 1
the following is my robot config file in yaml
# FLEET CONFIG =================================================================
# RMF Fleet parameters
rmf_fleet:
  fleet_manager:
    prefix: "http://127.0.0.1:22022"
    user: "some_user"
    password: "some_password"
  limits:
    linear: [0.7, 0.5] # velocity, acceleration
    angular: [0.4, 1.0] # velocity, acceleration
  profile: # Robot profile is modelled as a circle
    footprint: 1.0 # radius in m
    vicinity: 1.2 # radius in m
  reversible: False # whether robots in this fleet can reverse
  # TODO Update battery parameters with actual specs
  battery_system:
    voltage: 12.0 # V
    capacity: 20.0 # Ahr
    charging_current: 10.0 # A
  mechanical_system:
    mass: 70.0 # kg
    moment_of_inertia: 40.0 #kgm^2
    friction_coefficient: 0.22
  ambient_system:
    power: 100.0 # W
  tool_system:
    power: 0.0 # W
  recharge_threshold: 0.20 # Battery level below which robots in this fleet will not operate
  recharge_soc: 1.0 # Battery level to which robots in this fleet should be charged up to during recharging tasks
  publish_fleet_state: 10.0 # Publish frequency for fleet state, ensure that it is same as robot_state_update_frequency
  account_for_battery_drain: True
  task_capabilities: # Specify the types of RMF Tasks that robots in this fleet are capable of performing
    loop: True
    delivery: True
    clean: False
    finishing_request: "park" # [park, charge, nothing]
# Originbot CONFIG =================================================================
robots:
  # Here the user is expected to append the configuration for each robot in the
  # fleet.
  # Configuration for originbot_0
  originbot_0:
    robot_config:
      max_delay: 15.0 # allowed seconds of delay of the current itinerary before it gets interrupted and replanned
    rmf_config:
      robot_state_update_frequency: 10.0
      start:
        map_name: "L1"
        waypoint: ""
        orientation: 0.0 # radians
      charger:
        waypoint: ""
  # Configuration for originbot_1
  originbot_1:
    robot_config:
    rmf_config:
      start:
        map_name: "L1"
        waypoint: "originbot_spawn"
      charger:
# TRANSFORM CONFIG =============================================================
# For computing transforms between Robot and RMF coordinate systems
# If its a 1:1 correspondance just place the same numbers
reference_coordinates:
  rmf: [[10.2837, -5.6326], # Right corner
         [5.3339, -0.3840], # Top Corner
         [0.2560, -5.2059], # Left Corner
         [4.8645, -9.8143], # Bottom Corner
         [3.7977, -4.3524], # Our seats
         [3.9684, -6.5713], # Circular Robot Base
         [6.2300, -3.4990], # Table leg on the right
         [6.8274, -6.2300], # Bottom Right Arm
         [8.5769, -8.9182]] # Island
  robot: [[8.04443, -1.89213], # Right corner
         [2.2344, 4.35452], # Top Corner
         [-3.61153, -1.37832], # Left Corner
         [1.50039, -692627], # Bottom Corner
         [0.462738, -0.356078], # Our seats
         [0.684927, -2.9862], # Circular Robot Base
         [3.30796, 0.658291], # Table leg on the right
         [4.03551, -2.54359], # Bottom Right Arm
         [5.95516, -5.64273]] # Island
this is my fleet adapter code (.py)
# Copyright 2021 Open Source Robotics Foundation, Inc.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#     http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import sys
import argparse
import yaml
import nudged
import time
import threading
import rclpy
import rclpy.node
from rclpy.parameter import Parameter
import rmf_adapter as adpt
import rmf_adapter.vehicletraits as traits
import rmf_adapter.battery as battery
import rmf_adapter.geometry as geometry
import rmf_adapter.graph as graph
import rmf_adapter.plan as plan
from rmf_task_msgs.msg import TaskProfile, TaskType
from functools import partial
from .RobotCommandHandle import RobotCommandHandle
from .RobotClientAPI import RobotAPI
# Helper functions
def initialize_fleet(config_yaml, nav_graph_path, node, use_sim_time, server_uri):
    # Profile and traits
    fleet_config = config_yaml['rmf_fleet']
    profile = traits.Profile(geometry.make_final_convex_circle(
        fleet_config['profile']['footprint']),
        geometry.make_final_convex_circle(fleet_config['profile']['vicinity']))
    vehicle_traits = traits.VehicleTraits(
        linear=traits.Limits(*fleet_config['limits']['linear']),
        angular=traits.Limits(*fleet_config['limits']['angular']),
        profile=profile)
    vehicle_traits.differential.reversible = fleet_config['reversible']
    # Battery system
    voltage = fleet_config['battery_system']['voltage']
    capacity = fleet_config['battery_system']['capacity']
    charging_current = fleet_config['battery_system']['charging_current']
    battery_sys = battery.BatterySystem.make(
        voltage, capacity, charging_current)
    # Mechanical system
    mass = fleet_config['mechanical_system']['mass']
    moment = fleet_config['mechanical_system']['moment_of_inertia']
    friction = fleet_config['mechanical_system']['friction_coefficient']
    mech_sys = battery.MechanicalSystem.make(mass, moment, friction)
    # Power systems
    ambient_power_sys = battery.PowerSystem.make(
        fleet_config['ambient_system']['power'])
    tool_power_sys = battery.PowerSystem.make(
        fleet_config['tool_system']['power'])
    # Power sinks
    motion_sink = battery.SimpleMotionPowerSink(battery_sys, mech_sys)
    ambient_sink = battery.SimpleDevicePowerSink(
        battery_sys, ambient_power_sys)
    tool_sink = battery.SimpleDevicePowerSink(battery_sys, tool_power_sys)
    nav_graph = graph.parse_graph(nav_graph_path, vehicle_traits)
    # Adapter
    fleet_name = fleet_config['name']
    adapter = adpt.Adapter.make(f'{fleet_name}_fleet_adapter')
    if use_sim_time:
        adapter.node.use_sim_time()
                     "RMF Schedule Node is running")
    adapter.start()
    time.sleep(1.0)
    fleet_handle = adapter.add_fleet(fleet_name, vehicle_traits, nav_graph, server_uri)
    if not fleet_config['publish_fleet_state']:
        fleet_handle.fleet_state_publish_period(None)
    # Account for battery drain
    drain_battery = fleet_config['account_for_battery_drain']
    recharge_threshold = fleet_config['recharge_threshold']
    recharge_soc = fleet_config['recharge_soc']
    finishing_request = fleet_config['task_capabilities']['finishing_request']
    node.get_logger().info(f"Finishing request: [{finishing_request}]")
    # Set task planner params
    ok = fleet_handle.set_task_planner_params(
        battery_sys,
        motion_sink,
        ambient_sink,
        tool_sink,
        recharge_threshold,
        recharge_soc,
        drain_battery,
        finishing_request)
    assert ok, ("Unable to set task planner params")
    task_capabilities = []
    if fleet_config['task_capabilities']['loop']:
            f"Fleet [{fleet_name}] is configured to perform Loop tasks")
        task_capabilities.append(TaskType.TYPE_LOOP)
    if fleet_config['task_capabilities']['delivery']:
            f"Fleet [{fleet_name}] is configured to perform Delivery tasks")
        task_capabilities.append(TaskType.TYPE_DELIVERY)
    if fleet_config['task_capabilities']['clean']:
            f"Fleet [{fleet_name}] is configured to perform Clean tasks")
        task_capabilities.append(TaskType.TYPE_CLEAN)
    # Callable for validating requests that this fleet can accommodate
    def _task_request_check(task_capabilities, msg: TaskProfile):
        if msg.description.task_type in task_capabilities:
            return True
        else:
            return False
    fleet_handle.accept_task_requests(
        partial(_task_request_check, task_capabilities))
    # Transforms
    rmf_coordinates = config_yaml['reference_coordinates']['rmf']
    robot_coordinates = config_yaml['reference_coordinates']['robot']
    transforms = {
        'rmf_to_robot': nudged.estimate(rmf_coordinates, robot_coordinates),
        'robot_to_rmf': nudged.estimate(robot_coordinates, rmf_coordinates)}
    transforms['orientation_offset'] = \
        transforms['rmf_to_robot'].get_rotation()
    mse = nudged.estimate_error(transforms['rmf_to_robot'],
                                rmf_coordinates,
                                robot_coordinates)
    print(f"Coordinate transformation error: {mse}")
    print("RMF to Robot transform:")
    print(f"    rotation:{transforms['rmf_to_robot'].get_rotation()}")
    print(f"    scale:{transforms['rmf_to_robot'].get_scale()}")
    print(f"    trans:{transforms['rmf_to_robot'].get_translation()}")
    print("Robot to RMF transform:")
    print(f"    rotation:{transforms['robot_to_rmf'].get_rotation()}")
    print(f"    scale:{transforms['robot_to_rmf'].get_scale()}")
    print(f"    trans:{transforms['robot_to_rmf'].get_translation()}")
    def _updater_inserter(cmd_handle, update_handle):
        """Insert a RobotUpdateHandle."""
        cmd_handle.update_handle = update_handle
    # Initialize robot API for this fleet
    api = RobotAPI(
        fleet_config['fleet_manager']['prefix'],
        fleet_config['fleet_manager']['user'],
        fleet_config['fleet_manager']['password'],
        fleet_config['name'],
        timeout = 5.0,
        debug = False)
    # Initialize robots for this fleet
    missing_robots = config_yaml['robots']
    def _add_fleet_robots():
        robots = {}
        while len(missing_robots) > 0:
            time.sleep(0.2)
            for robot_name in list(missing_robots.keys()):
                node.get_logger().debug(f"Connecting to robot: {robot_name}")
                position = api.position(robot_name)
                if position is None:
                    continue
                if len(position) > 2:
                    node.get_logger().info(f"Initializing robot: {robot_name}")
                    robots_config = config_yaml['robots'][robot_name]
                    rmf_config = robots_config['rmf_config']
                    robot_config = robots_config['robot_config']
                    initial_waypoint = rmf_config['start']['waypoint']
                    initial_orientation = rmf_config['start']['orientation']
                    starts = []
                    time_now = adapter.now()
                    if (initial_waypoint is not None) and\
                            (initial_orientation is not None):
                            f"Using provided initial waypoint "
                            "[{initial_waypoint}] "
                            f"and orientation [{initial_orientation:.2f}] to "
                            f"initialize starts for robot [{robot_name}]")
                        # Get the waypoint index for initial_waypoint
                        initial_waypoint_index = nav_graph.find_waypoint(
                            initial_waypoint).index
                        starts = [plan.Start(time_now,
                                             initial_waypoint_index,
                                             initial_orientation)]
                    else:
                            f"Running compute_plan_starts for robot: "
                            "{robot_name}")
                        starts = plan.compute_plan_starts(
                            nav_graph,
                            rmf_config['start']['map_name'],
                            position,
                            time_now)
                    if starts is None or len(starts) == 0:
                        node.get_logger().error(
                            f"Unable to determine StartSet for {robot_name}")
                        continue
                    robot = RobotCommandHandle(
                        name=robot_name,
                        fleet_name=fleet_name,
                        config=robot_config,
                        node=node,
                        graph=nav_graph,
                        vehicle_traits=vehicle_traits,
                        transforms=transforms,
                        map_name=rmf_config['start']['map_name'],
                        start=starts[0],
                        position=position,
                        charger_waypoint=rmf_config['charger']['waypoint'],
                        update_frequency=rmf_config.get(
                            'robot_state_update_frequency', 1),
                        adapter=adapter,
                        api=api)
                    if robot.initialized:
                        robots[robot_name] = robot
                        # Add robot to fleet
                        fleet_handle.add_robot(robot,
                                               robot_name,
                                               profile,
                                               [starts[0]],
                                               partial(_updater_inserter,
                                                       robot))
                            f"Successfully added new robot: {robot_name}")
                    else:
                            f"Failed to initialize robot: {robot_name}")
                    del missing_robots[robot_name]
                else:
                    pass
                        f"{robot_name} not found, trying again...")
        return
    add_robots = threading.Thread(target=_add_fleet_robots, args=())
    add_robots.start()
    return adapter
# Main
def main(argv=sys.argv):
    # Init rclpy and adapter
    rclpy.init(args=argv)
    adpt.init_rclcpp()
    args_without_ros = rclpy.utilities.remove_ros_args(argv)
    parser = argparse.ArgumentParser(
        prog="fleet_adapter",
        description="Configure and spin up the fleet adapter")
    parser.add_argument("-c", "--config_file", type=str, required=True,
                        help="Path to the config.yaml file")
    parser.add_argument("-n", "--nav_graph", type=str, required=True,
                        help="Path to the nav_graph for this fleet adapter")
    parser.add_argument("-s", "--server_uri", type=str, required=False, default="",
                    help="URI of the api server to transmit state and task information.")
    parser.add_argument("--use_sim_time", action="store_true",
                        help='Use sim time, default: false')
    args = parser.parse_args(args_without_ros[1:])
    print(f"Starting fleet adapter...")
    config_path = args.config_file
    nav_graph_path = args.nav_graph
    # Load config and nav graph yamls
    with open(config_path, "r") as f:
        config_yaml = yaml.safe_load(f)
    # ROS 2 node for the command handle
    fleet_name = config_yaml['rmf_fleet']['name']
    node = rclpy.node.Node(f'{fleet_name}_command_handle')
    # Enable sim time for testing offline
    if args.use_sim_time:
        param = Parameter("use_sim_time", Parameter.Type.BOOL, True)
        node.set_parameters([param])
    if args.server_uri == "":
        server_uri = None
    else:
        server_uri = args.server_uri
        config_yaml,
        nav_graph_path,
        node,
        args.use_sim_time,
        server_uri)
    # Create executor for the command handle node
    rclpy_executor = rclpy.executors.SingleThreadedExecutor()
    rclpy_executor.add_node(node)
    # Start the fleet adapter
    rclpy_executor.spin()
    # Shutdown
    node.destroy_node()
    rclpy_executor.shutdown()
    rclpy.shutdown()
if __name__ == '__main__':
    main(sys.argv)
RMF is sometimes very bad in reporting the errors. It could be a lot of things.
Skiming along your code I see:
  1. in the yaml file, one of the robots staring waypoints is empty “originbot_0”, why? TRy imitating the exact yaml given in the examples.
    Also remember that you have to start all the systems, both the server and the client lets say. I would encourage to go over the examples and mimic it as much as possible in your local setup. Then change the robot names and things like that…Step by step so that you detect when it stops working. Also do you have a simulation in a ROSject or git that you can share? That way we might be able to debug a bit better, test and see what could be wrong.
hi, i have most things sorted out, but my rmf system is unable to detect the presence of my robot. I use ssh to communicate with my robot from my device, was wondering how to implement code such that the adapter would be able to communicate with my robot, and thus be able to identify it and assign tasks to it. not 100% sure which codes will be needed for reference, but will send some code here. (no github rosprojects)
am also getting this error message when starting up the fleet adapter.
Coordinate transformation error: 40041472014.35689
rotation:0.1669748345397551
scale:22436.581919543834
trans:[-144220.278841231, 26674.508565925025]
rotation:-0.16697483453975506
scale:6.903932766499679e-06
trans:[5.659233432489587, -5.09914031887319]
fleet_adapter.py
import sys
import argparse
import yaml
import nudged
import time
import threading
import rclpy
import rclpy.node
# Helper functions
        profile=profile)
    # Battery system
    # Mechanical system
    # Power systems
    # Power sinks
    # Adapter
    if use_sim_time:
    adapter.start()
    time.sleep(1.0)
        battery_sys,
        motion_sink,
        ambient_sink,
        tool_sink,
        recharge_threshold,
        recharge_soc,
        drain_battery,
        finishing_request)
            return True
        else:
            return False
    # Transforms
    transforms = {
                                rmf_coordinates,
                                robot_coordinates)
    api = RobotAPI(
        fleet_config['fleet_manager']['password'])
        robots = {}
            time.sleep(0.2)
                    continue
                    starts = []
                    else:
                            "{robot_name}")
                            nav_graph,
                            position,
                            time_now)
                        continue
                        name=robot_name,
                        node=node,
                        graph=nav_graph,
                        start=starts[0],
                        position=position,
                        adapter=adapter,
                        api=api)
                                               robot_name,
                                               profile,
                                               [starts[0]],
                                                       robot))
                    else:
                else:
                    pass
        return
    add_robots.start()
    return adapter
# Main
    adpt.init_rclcpp()
        server_uri = None
    else:
        config_yaml,
        nav_graph_path,
        node,
        args.use_sim_time,
        server_uri)
    # Shutdown
    node.destroy_node()
    rclpy.shutdown()
    main(sys.argv)
originbot_config.yaml
(commented out the originbot_0 segment as it is not implemented yet)
rmf_fleet:
  fleet_manager:
    prefix: "http://127.0.0.1:8000"
    user: "some_user"
  limits:
  battery_system:
    voltage: 12.0 # V
  mechanical_system:
    mass: 70.0 # kg
  ambient_system:
    power: 100.0 # W
  tool_system:
    power: 0.0 # W
    loop: True
    delivery: True
    clean: False
robots:
  # fleet.
#  originbot_0:
#    robot_config:
#      max_delay: 15.0 # allowed seconds of delay of the current itinerary before it gets interrupted and replanned
#    rmf_config:
#      robot_state_update_frequency: 10.0
#      start:
#        map_name: "L1"
#        waypoint: ""
#        orientation: 0.0 # radians
#      charger:
#        waypoint: ""
  originbot_1:
    robot_config:
    rmf_config:
      start:
        map_name: "L1"
      charger:
