When I try to saveas a config, I am unable to enter a name in the ‘FIle name’ text box. The only work around I have is that, in case you have access to an already saved file, select it, then save it at your preferred location and afterwards rename it.
Only once was I actually able to enter text into the ‘File name’ filed and at that time I had surmised that that was due to the config having errors in it. Now, it is completely fine, yet this is the issue.
Any ideas how I can prevent this from happening again?
