<?xml version="1.0" encoding="UTF-8"?>
<launch>
<arg name="x" default="0.0" />
<arg name="y" default="0.0" />
<arg name="z" default="0.0" />
<arg name="urdf_robot_file" default="" />
<arg name="robot_name" default="" />
<!-- This Version was created due to some errors seen in the V1 that crashed GAzebo or went too slow in spawn -->
<!-- Load the URDF into the ROS Parameter Server -->
<param name="robot_description" command="cat $(arg urdf_robot_file)" />
<!-- Run a python script to the send a service call to gazebo_ros to spawn a URDF robot -->
<node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen"
args="-urdf -x $(arg x) -y $(arg y) -z $(arg z) -model $(arg robot_name) -param robot_description"/>
</launch>
In the urdf_spawn.launch file, what does it truly mean with the syntax:
<arg name="x" value="0.0"/>
Is it the position of the robot or something else?
Also, in this part of the code;
What does each -urdf -x -y -z -model etc. actually do? Is there a more intuitive way to explain this?
