Hi @richard.valenzuela-zavala191 ,
There are two things that you can do to avoid this error:
- You can compile only that package using
colcon build:
cd ~/ros2_ws
colcon build --packages-select my_box_bot_description
source install/setup.bash
launch my_box_bot_description urdf_visualize.launch.py
- You can delete the
build,installandlogfolders and rebuild all packages from scratch:
cd ~/ros2_ws
rm -rf ./build ./install ./log
colcon build
Try the first option. If it does not work, then try the second.
If neither works, then let us know.
