Hi @staff my queries are as follows:
Questions 1:
In unit 1, inorder to create a package for creating URDF models, we use the below-mentioned code. My question is why we are adding all these as dependencies when in previous cases we were able to access these dependent packages through launch files (even when the only dependency was rospy)?
cd /home/user/catkin_ws/src
catkin_create_pkg my_mira_description rospy rviz controller_manager gazebo_ros joint_state_publisher robot_state_publisher
Launch file:
<launch>
<!-- USE: roslaunch my_mira_description urdf_visualize.launch model:='$(find myrobot_package)/urdf/myrobot.urdf' -->
<arg name="model" default=""/>
<param name="robot_description" command="cat $(arg model)" />
<!-- send fake joint values -->
<node name="joint_state_publisher_gui" pkg="joint_state_publisher_gui" type="joint_state_publisher_gui"/>
<!-- Combine joint values -->
<node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher"/>
<!-- Show in Rviz -->
<!--<node name="rviz" pkg="rviz" type="rviz" args="-d $(find my_mira_description)/rviz_config/urdf.rviz"/>-->
<node name="rviz" pkg="rviz" type="rviz" args=""/>
</launch>
Question 2:
We use RGBA to define the color of the material in Rviz using a scale of 0 to 1 for each value. Now, can i know why we are using a scale of 0 to 1 when the standard representation for RGBA is 0 to 255. Is it special for ROS?
Question 3:
In unit 2, 1.5 Learn how to import your 3D CAD models to Gazebo
In blender, after setting the origin to the center of mass, why are we aligning the center of mass (now origin) with axis of plain?
In blender after importing the dae file into ros, we also assign to it the files model.sdf and model.config. In model.config file, the tag
<sdf version =”1.5”>model.sdf</sdf>shows the sdf file we are using but no path mentioned, only its name. Is it assumed that they will always be in the same folder? -
What is SDF tag for? its not used in any of the URDF we worked on the course.
Is it right to say that the content of any .dae file we import into ROS will store the mesh of the model, its color, units and its origin(at center of mass).
Why is the origin we set using blender always at the center of mass? What if its a model of a robot arm, whose center of mass might be at its center, but we want it to move along one of its edges to mimic shoulder movement. Will the origin still be at the center?
Feedback:
Please update the above video. Here we are taught how to import a 3d model into Gazebo, but this video talks of a bug in blender which offset the result.Due to this the tutorial was made containing the bug. Please upload a bug free version so that i can see the end result should really look like.
I found a youtube video that i think you would like that solves this. this uses fusion 360 and seems kind of straightforward, at least solving the center of mass offset issue faced in blender.
Question 4:
In unit 3 - Using URDF for Gazebo, under Inertia
Is it safe to say that origin tag used in inertial tag, visual tag and collision tag are all in reference to the origin (assigned to the center of mass) of the model we assigned in blender?
Question 5:
For the Gurdy robot, under for root link called base_link, we are giving it a visual tag of a box of sides 0.01 and we are giving a hemispherical mesh for the head. I am able to see the mesh of the head, but where is the box mentioned in base_link in the simulation under visual tag?
<link name="base_link">
<collision>
<geometry>
<box size="0.01 0.01 0.01"/>
</geometry>
</collision>
<visual>
<origin xyz="0 0 0.01" rpy="0 0 0"/>
<geometry>
</geometry>
</visual>
</link>
<link name="head_link">
<inertial>
<origin xyz="0 0 0.02" rpy="0 0 0"/>
<mass value="0.01" />
<inertia ixx="7.58333333333e-07" ixy="0.0" ixz="0.0" iyy="7.58333333333e-07" iyz="0.0" izz="1.25e-06"/>
</inertial>
<collision>
<geometry>
<cylinder radius="0.05" length="0.04"/>
</geometry>
</collision>
<visual>
<origin rpy="0.0 0 0" xyz="0 0 0"/>
<geometry>
<mesh filename="package://my_gurdy_description/models/gurdy/meshes/gurdy_head_v2.dae"/>
</geometry>
</visual>
</link>
While answering, i would really appreciate it if the question was quoted(
), then reply given for better readability.
The interest with which the construct team and members of the community have taken to answer my queries has given me encouragement to post new ones. Thanks in advance.
