I am going through the course URDF for Robot Modelling and at a section when I launch the Rviz GUI, I am asked to save the config file in the 'rvig_config" folder created in my package.
When I try to do so, I don’t see my folder in the dialog box and if I just save it it gives me an error that is as shown below:
Where exactly are you saving it? Because the /opt path only can be written by sudos.
Could you paste here the path? It should be inside the /home/user/
I have a question regarding this part. In fact, i launched the rviz.launch but i did not get any red box displayed.
Could someone give me some hint ?
Check that the urdf is correctly linked and has the parameters correct, because sometimes when there is some issue inside , it just doesn’t display anything
