URDF understanding of coordinates
I dont understand how position can be chosen. Even if it is a rough guess i didnt get clear picture of it and also I didn’t understand rool, pitch, yaw positions for each parent link. Can you explain it a bit in an intuitive way.
So in URDFS/XACROS you pasition an element in basically two ways that get combined if used both:
  1. Is through the origin tag in the links elements. There you can position the visual/collision/inertia elements repect to the origin of that link. This is used to reposition meshes because their origin was not set properly or to set the inertia origin in a different place to change the phyisical behaviour.
  2. When you use a joint to connect two links. Ths will position the child links reffered to the parents origin. This is where you can position the different parts of a robot, is like the assembly.
As for the Roll pitch and yaw, there are the angles with which you define the ORIENTATION of a LINK. Lets say if you want the arm part of a robot to be oriented forward when assembling it , here is where you have to work.
Roll : Is how many radians to rotate the link around the X axis of that same link.
Pitch: is how many radians you rotate the link around the Y axis of that same link
Yaw: is how many radians you rotate the link around the Z axis of that same link
These definitions can vary specially if the axis have been changed. But that’s the theory.
Hi
can you help me please to understand how you choose the values of this code of Exercise 2.2 Unit 2 Mastering with Gazebo :
<?xml version="1.0" ?>
    <collision>
        <geometry>
            <box size="2 1.3 0.4" />
        </geometry>
    </collision>
    <visual>
        <geometry>
        </geometry>
        <material name="DarkBlue">
            <color rgba="0.2 0.2 0.4 1" />
        </material>
    </visual>
</link>
<!-- Joint - caster wheel -->
<joint name="joint_chassis_caster_wheel" type="fixed">
    <origin rpy="0 0 0" xyz="0.8 0 -0.15" />
    <child link="link_caster_wheel" />
    <parent link="link_chassis" />
    <joint_properties damping="1.0" friction="1.0" />
</joint>
<!-- Link - caster wheel -->
<link name="link_caster_wheel">
    <inertial>
        <mass value="1" />
        <inertia ixx="0.002526666666667" ixy="0" ixz="0" iyy="0.002526666666667" iyz="0" izz="0.005"/>
    </inertial>
    <!-- Caster wheel support -->
    <collision>
        <origin rpy="0 0 0" xyz="0 0 -0.03" />
        <geometry>
            <sphere radius="0.2" />
        </geometry>
    </collision>
    <visual>
        <geometry>
        </geometry>
        </material>
    </visual>
    <!-- Caster wheel -->
    <collision>
        <origin rpy="0 0 0" xyz="0 0 -0.15" />
        <geometry>
            <sphere radius="0.10" />
        </geometry>
    </collision>
    <visual>
        <geometry>
        </geometry>
        <material name="Grey">
            <color rgba="0.6 0.6 0.6 1" />
        </material>
    </visual>
</link>
<!-- Joint - chassis / left wheel -->
<joint name="joint_chassis_left_wheel" type="continuous">
    <origin rpy="0 0 0" xyz="-0.5 0.65 0" />
    <child link="link_left_wheel" />
    <axis rpy="0 0 0" xyz="0 1 0" />
    <limit effort="10000" velocity="1000" />
</joint>
<!-- Link - left wheel -->
<link name="link_left_wheel">
    <inertial>
        <mass value="1" />
    </inertial>
    <!-- Tires -->
    <collision>
        <origin rpy="1.5707 0 0" xyz="0 0.18 0" />
        <geometry>
            <cylinder length="0.12" radius="0.4"/>
        </geometry>
    </collision>
    <visual>
        <geometry>
        </geometry>
        <material name="Black">
            <color rgba="0.1 0.1 0.1 1" />
        </material>
    </visual>
    <!-- Axle -->
    <collision>
        <origin rpy="1.5707 0 0" xyz="0 0.06 0" />
        <geometry>
            <cylinder length="0.12" radius="0.08"/>
        </geometry>
    </collision>
    <visual>
        <geometry>
        </geometry>
        </material>
    </visual>
    <!-- Hubcap -->
    <visual>
        <origin rpy="1.5707 0 0" xyz="0 0.25 0" />
        <geometry>
            <box size="0.02 0.5 0.02" />
        </geometry>
        </material>
    </visual>
</link>
<!-- Joint - chassis / right wheel -->
<joint name="joint_chassis_right_wheel" type="continuous">
    <origin rpy="0 0 0" xyz="-0.5 -0.65 0" />
    <child link="link_right_wheel" />
</joint>
<!-- Link - right wheel -->
<link name="link_right_wheel">
    <inertial>
        <mass value="1" />
    </inertial>
    <!-- Tires -->
    <collision>
        <origin rpy="1.5707 0 0" xyz="0 -0.18 0" />
        <geometry>
        </geometry>
    </collision>
    <visual>
        <geometry>
        </geometry>
        </material>
    </visual>
    <!-- Axle -->
    <collision>
        <origin rpy="1.5707 0 0" xyz="0 -0.06 0" />
        <geometry>
        </geometry>
    </collision>
    <visual>
        <geometry>
        </geometry>
        </material>
    </visual>
    <!-- Hubcap -->
    <visual>
        <origin rpy="1.5707 0 0" xyz="0 -0.25 0" />
        <geometry>
        </geometry>
        </material>
    </visual>
</link>
