I am currently in Chapter 3 in the URDF course. I am facing problems with trying to visualize my robot mira in the rviz for some reason.
I tried copy and pasting the solution but the GraphicalTools are completely black screened and nothing pops out. Here’s a flow of what I did so you could possibly see what I did wrong;
# Execute in shell #1
roslaunch my_mira_description spawn_mira_geometric_collisions_inertias.launch
# Output in terminal
... logging to /home/user/.ros/log/270bd63a-cf7d-11eb-945c-0242ac1c0008/roslaunch-3_xterm-11843.log
Press Ctrl-C to interrupt
started roslaunch server http://3_xterm:38421/
SUMMARY
PARAMETERS
* /robot_description: <?xml version="1....
* /rosdistro: kinetic
* /rosversion: 1.12.14
NODES
urdf_spawner (gazebo_ros/spawn_model)
ROS_MASTER_URI=http://3_simulation:11311
process[urdf_spawner-1]: started with pid [11853]
SpawnModel script started
[INFO] [1623946002.380653, 0.000000]: Loading model XML from ros parameter
[INFO] [1623946002.383453, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[INFO] [1623946002.386742, 0.000000]: Calling service /gazebo/spawn_urdf_model
[INFO] [1623946002.633404, 3748.800000]: Spawn status: SpawnModel: Successfully spawned entity
[urdf_spawner-1] process has finished cleanly
log file: /home/user/.ros/log/270bd63a-cf7d-11eb-945c-0242ac1c0008/urdf_spawner-1*.log
done
However, nothing emerges from the gazebo.
I also checked if mira is really spawned or not using :
rosservice call /gazebo/get_world_properties
…and mira is indeed there.
Can you point out what I did wrong?
