@staff I tried messing up the hyperlink with random characters, but it still generated the URDF.Is the hyperlink just used just to act as a unique namespace or does the compiler actually visit this site and extract some syntax from it?
Hi @Joseph1001,
I think having a look at XML Namespaces will help better than I trying to explain it to you with my own words:
Hi @ralves ,
I have gone through the link you shared. My understanding is as below:
The purpose of using an URI is to give the namespace a unique name.
However, companies often use the namespace as a pointer to a web page containing namespace information.
The second point is the one i am having difficulty with. Does it mean that some info is extracted from that hyper link or is it simply for the user to understand the syntax used?
Hi @Joseph1001,
Since “http://www.ros.org/wiki/xacro” does not contain structured information in a way that can be easily parsed, I would go for the second option:
Is it simply for the user to understand the syntax used
But I’ve had already experiences where the namespace is parsed (not in the xacro case), and putting a strange value in the namespace wouldn’t work.
I think having a look at XML Schema may also be helpful.
Hi @ralves ,
Thanks for helping out. The solution seem obvious now.
