Hello, I’m struggling with getting the launch file to work properly in the intro course.
I followed the following forum posts, and neither worked for me.
I made sure all proper edits to files were made, Here are my setup.py, two_rover_heartbeat.launch.py, and heartbeat.py. When I was unable to debug them myself, I copy/pasted them from the course examples and it still would not see my launch file after
cd ~/ros2_ws
source install/setup.bash
colcon build
ros2 launch mars_rover_systems [TAB][TAB]
any help would be appreciated.
heartbeat.py -----------------------------------------------
#!/usr/bin/env python
import rclpy
from rclpy.node import Node
import time
class HeartbeatNode(Node):
def __init__(self,rover_name,timer_period = 0.2):
self.rover_name = rover_name
super().__init__(self.rover_name)
self.create_timer(timer_period,self.timer_callback)
def timer_callback(self):
timestamp = self.get_clock().now()
self.get_logger().info(str(self.rover_name) + str(" is alive. ") + "T:" + str(timestamp))
def main(args = None):
rclpy.init(args=args)
#create node
node = HeartbeatNode('mars_rover_1',timer_period=0.5)
rclpy.spin(node)
rclpy.shutdown()
def main2(args = None):
#create node
node = HeartbeatNode('mars_rover_2',timer_period=0.5)
rclpy.spin(node)
rclpy.shutdown()
if __name__ == '__main__':
main()
two_rover_heartbeat.launch.py---------------------------------------------------------------
return LaunchDescription([
Node(
package='mars_rover_systems',
executable='heartbeat_executable',
output='screen'),
Node(
executable='heartbeat_executable_2',
output='screen')
setup.py ---------------------------------------------------------------
from setuptools import find_packages, setup
import os
from glob import glob
package_name = 'mars_rover_systems'
setup(
name=package_name,
version='0.0.0',
packages=find_packages(exclude=['test']),
data_files=[
zip_safe=True,
maintainer='user',
tests_require=['pytest'],
entry_points={
'console_scripts': [
'heartbeat_executable = mars_rover_systems.heartbeat:main',
'heartbeat_executable_2 = mars_rover_systems.heartbeat:main2'
