vkuehn
March 12, 2023, 5:30pm
1
it did hit me again, no launch file found when launching the robot arm
ros2 launch my_robot_arm_description
the launfile exists in
nstall/my_robot_arm_description/share/my_robot_arm_description/launch/my_robot_arm.launch.py
any idea why it was not found ?
Hi @vkuehn ,
If the launch file is missing in your package, but exists in install folder, then copy that file into your launch folder path.
If you have a launch file in your package and you get an error saying launch file does not exist, then try deleting the build, install and log folders and rebuild your packages.
I hope this helps.
Hi @vkuehn ,
are you sure you pasted the entire command?
This command here is missing the name of the launch file:
The entire command is:
ros2 launch <name_of_the_package> <name_of_the_launch_file>
Perhaps that was the problem?
Cheers,
Roberto
vkuehn
March 13, 2023, 7:24pm
4
Hi @girishkumar.kannan @rzegers ,
thanks to you both !
Actually both was requiered (Delete build folders and add the correct launch file)
starts now thanks.
unfortunatetly can only mark one answer as solution
system
Closed
March 18, 2023, 7:25pm
5
