I am learning to use openai ROS package using the fect robot example. However I am getting a hard time to make the fetch robot simulation working. I am using ROS noetic. You can find the detailed question by following link https://answers.ros.org/question/373461/fetch-robot-simple-simulation/
You might need to install other packages and dpednencies, butthe base is there. This is the basic instalation used for the course of OpenAI_ROS in Noetic , so it should work.
I’m not able to access the ‘noetic_support’ branch in the last repo moveit_python.
I get the error “fatal: Remote branch noetic_support not found in upstream origin”
