Hello Everyone,
DISTRO: Humble
Gazebo: Fortress
I have been working with ros2_control extensively for past 5-6 months. But recently I have been facing a very weird issue. The same program that used to work before is not working anymore. Mainly the joint state broadcaster is not loading. I have attached the error and the launch file. This is for rosbot_xl. I would appreciate it if anyone can help regarding this.
#!/usr/bin/env python3
# Copyright 2020 ros2_control Development Team
# Copyright 2024 Husarion sp. z o.o.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
from launch.actions import DeclareLaunchArgument, OpaqueFunction, RegisterEventHandler
from launch.conditions import UnlessCondition
from launch.event_handlers import OnProcessExit
from launch.substitutions import (
Command,
FindExecutable,
LaunchConfiguration,
PathJoinSubstitution,
PythonExpression,
from launch_ros.actions import Node, SetParameter
from launch_ros.substitutions import FindPackageShare
def launch_setup(context, *args, **kwargs):
namespace = LaunchConfiguration("namespace").perform(context)
controller_manager_name = "controller_manager"
if namespace != "":
controller_manager_name = namespace + "/" + controller_manager_name
joint_state_broadcaster_spawner = Node(
package="controller_manager",
executable="spawner",
arguments=[
"joint_state_broadcaster",
"--controller-manager",
controller_manager_name,
"--controller-manager-timeout",
"120",
"--namespace",
namespace,
robot_controller_spawner = Node(
name=LaunchConfiguration(
"robot_controller_spawner_name",
default=[namespace, "_robot_controller_spawner"],
arguments=[
"rosbot_xl_base_controller",
"120",
"--namespace",
namespace,
delay_robot_controller_spawner_after_joint_state_broadcaster_spawner = RegisterEventHandler(
event_handler=OnProcessExit(
target_action=joint_state_broadcaster_spawner,
on_exit=[robot_controller_spawner],
imu_broadcaster_spawner = Node(
"imu_spawner_name", default=[namespace, "_imu_broadcaster_spawner"]
arguments=[
"imu_broadcaster",
"120",
"--namespace",
namespace,
delay_imu_broadcaster_spawner_after_robot_controller_spawner = RegisterEventHandler(
target_action=robot_controller_spawner,
on_exit=[imu_broadcaster_spawner],
return [
delay_robot_controller_spawner_after_joint_state_broadcaster_spawner,
delay_imu_broadcaster_spawner_after_robot_controller_spawner,
declare_namespace_arg = DeclareLaunchArgument(
"namespace",
default_value="",
description="Namespace for all topics and tfs",
mecanum = LaunchConfiguration("mecanum")
declare_mecanum_arg = DeclareLaunchArgument(
"mecanum",
default_value="False",
description="Whether to use mecanum drive controller, otherwise use diff drive",
camera_model = LaunchConfiguration("camera_model")
declare_camera_model_arg = DeclareLaunchArgument(
"camera_model",
default_value="None",
description="Add camera model to the robot URDF",
choices=[
"None",
"intel_realsense_d435",
"orbbec_astra",
"stereolabs_zed",
"stereolabs_zedm",
"stereolabs_zed2",
"stereolabs_zed2i",
"stereolabs_zedx",
"stereolabs_zedxm",
lidar_model = LaunchConfiguration("lidar_model")
declare_lidar_model_arg = DeclareLaunchArgument(
"lidar_model",
description="Add LiDAR model to the robot URDF",
choices=[
"None",
"slamtec_rplidar_a2",
"slamtec_rplidar_a3",
"slamtec_rplidar_s1",
"slamtec_rplidar_s2",
"slamtec_rplidar_s3",
"velodyne_puck",
include_camera_mount = LaunchConfiguration("include_camera_mount")
declare_include_camera_mount_arg = DeclareLaunchArgument(
"include_camera_mount",
description="Whether to include camera mount to the robot URDF",
use_sim = LaunchConfiguration("use_sim")
declare_use_sim_arg = DeclareLaunchArgument(
"use_sim",
description="Whether simulation is used",
simulation_engine = LaunchConfiguration("simulation_engine")
declare_simulation_engine_arg = DeclareLaunchArgument(
"simulation_engine",
default_value="ignition-gazebo",
description="Which simulation engine will be used",
controller_config_name = PythonExpression(
"'mecanum_drive_controller.yaml' if ",
mecanum,
" else 'diff_drive_controller.yaml'",
controller_config_path = PathJoinSubstitution(
FindPackageShare("rosbot_xl_controller"),
"config",
controller_config_name,
robot_description_content = Command(
PathJoinSubstitution([FindExecutable(name="xacro")]),
FindPackageShare("rosbot_xl_description"),
"urdf",
"rosbot_xl.urdf.xacro",
" controller_config_file:=",
controller_config_path,
" mecanum:=",
mecanum,
" lidar_model:=",
lidar_model,
" camera_model:=",
camera_model,
" include_camera_mount:=",
include_camera_mount,
" use_sim:=",
use_sim,
" simulation_engine:=",
simulation_engine,
" namespace:=",
namespace,
robot_description = {"robot_description": robot_description_content}
control_node = Node(
executable="ros2_control_node",
parameters=[
robot_description,
remappings=[
("imu_sensor_node/imu", "/_imu/data_raw"),
("~/motors_cmd", "/_motors_cmd"),
("~/motors_response", "/_motors_response"),
("rosbot_xl_base_controller/cmd_vel_unstamped", "cmd_vel"),
("/tf", "tf"),
("/tf_static", "tf_static"),
condition=UnlessCondition(use_sim),
namespace=namespace,
robot_state_pub_node = Node(
package="robot_state_publisher",
executable="robot_state_publisher",
output="both",
parameters=[robot_description],
remappings=[("/tf", "tf"), ("/tf_static", "tf_static")],
return LaunchDescription(
declare_namespace_arg,
declare_mecanum_arg,
declare_lidar_model_arg,
declare_camera_model_arg,
declare_include_camera_mount_arg,
declare_use_sim_arg,
declare_simulation_engine_arg,
SetParameter(name="use_sim_time", value=use_sim),
control_node,
robot_state_pub_node,
OpaqueFunction(function=launch_setup),
