Global Costmap Not Updating with New Obstacles in ROS2
Required Info:
Operating System:
Ubuntu 22.04
ROS2 version:
Humble binaries
Hello everyone,
I am currently working on a navigation project using ROS2 and have encountered an issue with the global costmap. New obstacles are correctly detected and reflected in the local costmap, but they do not appear in the global costmap.
Problem Description
New obstacles are visible in the local costmap but are not shown in the global costmap.
Despite using the same laser scan data, the global costmap is not updating with the new obstacles.
Questions
What settings should I check to ensure that the global costmap reflects the same obstacle information as the local costmap?
Are there specific configurations in the global costmap’s obstacle layer that I should verify?
Has anyone experienced a similar issue and can share their insights or solutions?
Thank you in advance for your help!
here is my nav2 yaml and Screenshot of the current situation
`amcl:
  ros__parameters:
    use_sim_time: False
    alpha1: 0.2
    alpha2: 0.2
    alpha3: 0.2
    alpha4: 0.2
    alpha5: 0.2
    base_frame_id: "base_footprint"
    beam_skip_distance: 0.5
    beam_skip_error_threshold: 0.9
    beam_skip_threshold: 0.3
    do_beamskip: false
    global_frame_id: "map"
    lambda_short: 0.1
    laser_likelihood_max_dist: 2.0
    laser_max_range: 100.0
    laser_min_range: -1.0
    laser_model_type: "likelihood_field"
    max_beams: 60
    max_particles: 2000
    min_particles: 500
    odom_frame_id: "odom"
    pf_err: 0.05
    pf_z: 0.99
    recovery_alpha_fast: 0.0
    recovery_alpha_slow: 0.0
    resample_interval: 1
    robot_model_type: "nav2_amcl::DifferentialMotionModel"
    save_pose_rate: 0.5
    sigma_hit: 0.2
    tf_broadcast: true
    transform_tolerance: 1.0
    update_min_a: 0.2
    update_min_d: 0.25
    z_hit: 0.5
    z_max: 0.05
    z_rand: 0.5
    z_short: 0.05
    scan_topic: scan
amcl_map_client:
  ros__parameters:
    use_sim_time: False
amcl_rclcpp_node:
  ros__parameters:
    use_sim_time: False
bt_navigator:
  ros__parameters:
    use_sim_time: False
    global_frame: map
    robot_base_frame: base_link
    odom_topic: /odom
    default_bt_xml_filename: "navigate_w_replanning_and_recovery.xml"
    bt_loop_duration: 10
    default_server_timeout: 20
    enable_groot_monitoring: True
    groot_zmq_publisher_port: 1666
    groot_zmq_server_port: 1667
    plugin_lib_names:
    - nav2_compute_path_through_poses_action_bt_node
    - nav2_back_up_action_bt_node
    - nav2_spin_action_bt_node
    - nav2_wait_action_bt_node
    - nav2_recovery_node_bt_node
    - nav2_single_trigger_bt_node
    - nav2_is_battery_low_condition_bt_node
    - nav2_navigate_through_poses_action_bt_node
    - nav2_navigate_to_pose_action_bt_node
    - nav2_remove_passed_goals_action_bt_node
    - nav2_planner_selector_bt_node
    - nav2_controller_selector_bt_node
    - nav2_goal_checker_selector_bt_node
bt_navigator_rclcpp_node:
  ros__parameters:
    use_sim_time: False
controller_server:
  ros__parameters:
    use_sim_time: False
    controller_frequency: 10.0
    min_y_velocity_threshold: 0.5
    failure_tolerance: 0.3
    progress_checker_plugin: "progress_checker"
    goal_checker_plugins: ["general_goal_checker"]
    controller_plugins: ["FollowPath"]
    progress_checker:
      required_movement_radius: 0.5
      movement_time_allowance: 10.0
    general_goal_checker:
      stateful: True
      xy_goal_tolerance: 0.25
      yaw_goal_tolerance: 0.25
    FollowPath:
      min_vel_x: 0.0
      min_vel_y: 0.0
      max_vel_x: 0.7
      max_vel_y: 0.0
      max_vel_theta: 1.0
      min_speed_xy: 0.0
      max_speed_xy: 0.7
      min_speed_theta: 0.0
      acc_lim_x: 2.5
      acc_lim_y: 0.0
      acc_lim_theta: 3.2
      decel_lim_x: -2.5
      decel_lim_y: 0.0
      decel_lim_theta: -3.2
      vx_samples: 20
      vy_samples: 0
      vtheta_samples: 40
      sim_time: 2.0
      linear_granularity: 0.05
      angular_granularity: 0.025
      transform_tolerance: 0.2
      xy_goal_tolerance: 0.05
      trans_stopped_velocity: 0.25
      stateful: True
      BaseObstacle.scale: 0.02
      PathAlign.scale: 32.0
      GoalAlign.scale: 24.0
      PathDist.scale: 32.0
      GoalDist.scale: 24.0
      RotateToGoal.scale: 32.0
controller_server_rclcpp_node:
  ros__parameters:
    use_sim_time: False
local_costmap:
  local_costmap:
    ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      global_frame: odom
      use_sim_time: False
      rolling_window: true
      width: 3
      height: 3
      resolution: 0.05
      robot_radius: 0.35
      plugins: ["obstacle_layer", "voxel_layer", "inflation_layer"]
      inflation_layer:
        plugin: "nav2_costmap_2d::InflationLayer"
        inflation_radius: 1.0
        cost_scaling_factor: 0.5
      obstacle_layer:
        plugin: "nav2_costmap_2d::ObstacleLayer"
        enabled: True
        observation_sources: scan
        scan:
          topic: /scan
          max_obstacle_height: 2.0
          clearing: True
          marking: True
          data_type: "LaserScan"
      voxel_layer:
        plugin: "nav2_costmap_2d::VoxelLayer"
        enabled: True
        publish_voxel_map: True
        origin_z: 0.0
        z_resolution: 0.05
        z_voxels: 16
        mark_threshold: 0
        scan:
          topic: /scan
          clearing: True
          marking: True
          raytrace_max_range: 3.0
          raytrace_min_range: 0.0
          obstacle_max_range: 7.5
          obstacle_min_range: 0.0
      static_layer:
        map_subscribe_transient_local: True
      always_send_full_costmap: True
  local_costmap_client:
    ros__parameters:
      use_sim_time: False
  local_costmap_rclcpp_node:
    ros__parameters:
      use_sim_time: False
global_costmap:
  global_costmap:
    ros__parameters:
      update_frequency: 1.0
      publish_frequency: 1.0
      global_frame: map
      use_sim_time: true
      robot_radius: 0.35
      resolution: 0.05
      track_unknown_space: true
      plugins: ["static_layer", "obstacle_layer", "voxel_layer", "inflation_layer"]
      obstacle_layer:
        enabled: True
        scan:
          topic: /scan
          clearing: True
          marking: True
          raytrace_max_range: 7.0
      voxel_layer:
        enabled: True
        origin_z: 0.0
        z_resolution: 0.05
        z_voxels: 16
        mark_threshold: 0
        scan:
          topic: /scan
          clearing: True
          marking: True
      static_layer:
        plugin: "nav2_costmap_2d::StaticLayer"
      inflation_layer:
  global_costmap_client:
    ros__parameters:
      use_sim_time: True
  global_costmap_rclcpp_node:
    ros__parameters:
      use_sim_time: False
map_server:
  ros__parameters:
    use_sim_time: False
    yaml_filename: "map.yaml"
map_saver:
  ros__parameters:
    use_sim_time: False
    save_map_timeout: 5.0
    free_thresh_default: 0.25
    occupied_thresh_default: 0.65
planner_server:
  ros__parameters:
    expected_planner_frequency: 20.0
    use_sim_time: False
    planner_plugins: ["GridBased"]
    GridBased:
      plugin: "nav2_navfn_planner/NavfnPlanner"
      tolerance: 0.5
      use_astar: false
      allow_unknown: true
planner_server_rclcpp_node:
  ros__parameters:
    use_sim_time: False
recoveries_server:
  ros__parameters:
    costmap_topic: local_costmap/costmap_raw
    footprint_topic: local_costmap/published_footprint
    cycle_frequency: 10.0
    recovery_plugins: ["spin", "backup", "wait"]
    spin:
      plugin: "nav2_recoveries/Spin"
    backup:
      plugin: "nav2_recoveries/BackUp"
    wait:
      plugin: "nav2_recoveries/Wait"
    global_frame: odom
    transform_timeout: 0.1
    use_sim_time: true
    simulate_ahead_time: 2.0
    max_rotational_vel: 1.0
    min_rotational_vel: 0.4
    rotational_acc_lim: 3.2
robot_state_publisher:
  ros__parameters:
    use_sim_time: False
waypoint_follower:
  ros__parameters:
    loop_rate: 200
    stop_on_failure: false
    waypoint_task_executor_plugin: "wait_at_waypoint"
    wait_at_waypoint:
      plugin: "nav2_waypoint_follower::WaitAtWaypoint"
      enabled: True
      waypoint_pause_duration: 200
and here is my navigation2 launch file
    start_rviz = LaunchConfiguration('start_rviz')
    use_sim = LaunchConfiguration('use_sim')
    map_yaml_file = LaunchConfiguration(
        'map_yaml_file',
        default=PathJoinSubstitution(
                FindPackageShare('swerve_nav2'),
                'map',
                'map.yaml'
    params_file = LaunchConfiguration(
        'params_file',
                'param',
                'swerve_robot.yaml'
    nav2_launch_file_dir = PathJoinSubstitution(
            FindPackageShare('nav2_bringup'),
            'launch',
    rviz_config_file = PathJoinSubstitution(
            'rviz',
            'nav2.rviz'
return LaunchDescription([
    DeclareLaunchArgument(
        'start_rviz',
        default_value='true',
        description='Whether execute rviz2'),
        'use_sim',
        description='Start robot in Gazebo simulation'),
        'map_yaml_file',
        default_value=map_yaml_file,
        description='Full path to map file to load'),
        'params_file',
        default_value=params_file,
        description='Full path to the ROS2 parameters file to use for all launched nodes'),
    # DeclareLaunchArgument(
    #     'autostart',
    #     default_value='true',
    #     description='Automatically startup the nav2 stack'),
    IncludeLaunchDescription(
        PythonLaunchDescriptionSource([nav2_launch_file_dir, '/bringup_launch.py']),
        launch_arguments={
            'map': map_yaml_file,
            'use_sim_time': use_sim,
            'params_file': params_file,
            # 'autostart': autostart,
            # 'use_respawn': True,
        }.items(),
    Node(
        package='rviz2',
        executable='rviz2',
        name='rviz2',
        arguments=['-d', rviz_config_file],
        output='screen',
        condition=IfCondition(start_rviz)),
Hi @k012123600 ,
Welcome to this Community!
That is how it is supposed to be.
The local costmap is the controller and it gets the instantaneous environment perception updates.
The global costmap is the planner and relies on the map that was created and saved. Any new changes in the robot environment needs to be remapped with the cartographer so that those changes are reflected (updated) in to the global costmap.
The global costmap does not get updated when new objects are added to the robot environment during runtime.
The global costmap has all the non-movable objects mapped on the map file.
The local costmap has also the instantaneous objects on the map during robot runtime, along with the non-movable objects acquired from the global costmap.
You need to remap the whole environment with cartographer again.
No changes are required.
Just make sure that the layers are defined one after the other in this exact order: static_layer, obstacle_layer, inflation_layer.
This is not an issue. The global costmap will not update unless the environment is remapped. This is the concept which you have not understood (or overlooked).
I did not go through your code-snippets as the issue is concept-understanding based and not configuration based.
I hope this solved your issue.
