How do you control your robot using actuators and not joints?
Project description
I’m working on a ROS2 project where I want to simulate on Gazebo Garden an underactuated gripper.
In the urdf file, we can specify actuators like that;
  <transmission name="abduction_transmission">
    <type>transmission_interface/AbductionTransmission</type>
    <joint name="fingrip_finger1_base_joint">
        </joint>
    <joint name="fingrip_finger2_base_joint">
        </joint>
    <actuator name="abduction_actuator">
      <mechanicalReduction>1</mechanicalReduction>
      <hardwareInterface>hardware_interface/EffortActuatorInterface</hardwareInterface>
    </actuator>
  </transmission>
I create my own transmission plug-in in ros2_control.
Problem encountered
But in ros2_controllers, I can’t find anything about actuator controllers, there is none.
Whereas in ROS1, there were some…
Do you have any idea how to implement an actuator controller ? Or do I need to write it all the way ?
BR,
Alexis
Well, I was mistaken, there are none in ROS1 too.
Gonna built my own x)
Wish me good luck !
